Sticky Thread For MilAir IV
TinEar
Glen Burnie, Maryland
Adrian,
I'm putting some ZBW freqs in my scanner to see if I can hear them over the water. Would appreciate if you could validate what I have as accurate and any other freqs I should enter:
321.3 Barnstable
370.9 Barnstable
299.7 Calverton
306.3 Shelton
290.3 Barnstable
360.6 ?Sardi?
307.3 Barnstable
379.85 Calverton
269.3 Hyannis
Also have the following ZNY Oceanic freqs in my scanner:
354.0
381.6
Appreciate the help
Ron
Ron, here are the freqs I use for ZBW. They were taken from the last Letter To Airmen they published. I know there's a change for one of the sectors - either BOS or BOSOX sector I seem to remember. Perhaps one of the New England guys can straighten us out. I program just the closest few Sectors within ZBW which are on the list below.
Boston Center (ZBW)
Low:
135.8/259.1 SARDI 32
134.0/317.7 DXR 19
132.3/346.3 ERICK 33
123.85/269.2 PVD 34
128.75/290.3 CAPE 18
128.1/351.7 PWL 06
134.3/256.9 SWF 05
133.425/307.9 BOSOX 47
High:
124.525/299.7 HTO 31
125.575/290.35 IGN 20
127.825/370.9 BOS 46
Edit: Ron, I sent you the PDF version of the Letter To Airmen issued by Boston Center. It contains the maps showing the high and low sectors. I should mention that it's now three years old but it's the last one they published. Anyone else that wants it, send me your email address. The last one issued by New York Center was in 2008. Those are the only two Centers that publish their freqs - as far as I can determine.
jsoergel
Cincinnati/Dayton, OH
There's a sector map with frequencies for ZID and several for ZOB; don't know if they were official. They're fairly accurate, if not current.
jsoergel
DEECEE 51 is departing 1843Z - back to Andrews if I'm not mistaken - direct APE and switching over to ZID. If anyone gets it inbound on the box, please pass on the tail number.
mdmonitor
DEECEE 51 (KC-135R) working Dayton for vectors into Patterson. Said they will be in the radar pattern for an hour or so. NASA 806 (ER-2, N806NA) just showed up as well.
1743Z 126.900 TOWER - NASA 806 final for 23R, gear down
1747Z 126.900 - DEECEE 51 about 2 miles from ANNEE (23R), low approach at or above 1800
1750Z 126.900 - on the go, switching to Dayton
Jared,
1528 EDT- DC 51 just showed up here at ADW and is landing
TinEar
One of the Andrews KC-135s (57-1512, 756th ARS) returned to Andrews right around 1500 local. It was flying the CODY 01 mission and departed the McChord area this morning. It went out there on the 6th.
Re DECEE 51...it's 57-1487.
1534: EVAC 33113 (C-17A, 03-3113, 183rd AS MS-ANG Jackson) w/ADW Twr for landing runway 19R...118.4
1536: DECEE 51 Heavy (KC-135R, 57-1487, 756th ARS AFRC Andrews) w/ADW Twr for landing runway 19R...standby for gear...gear down...118.4
1542: ARMY 1944 (C-37A, 97-1944, OSACOM) w/ADW Twr for landing runway 19R...landing check in progress and he's got the helo in sight...118.4
1542: A couple of CT-ANG C-21As zipping by overhead at FL 350 and 370...84-0125 and 84-0128 respectively. Neither is displaying a correct callsign...the first is showing ANG84125 and the other is SPACE01 which he always shows.
HANK 42 (C-130H, 85-0042, 347th AS Maxwell) also passed through the area at FL 240.
1607: HAWK 01 (C-21A, 84-0098, 457th AS Andrews) (several calls to ADW Twr before establishing contact) reports 5 out, gear down, full stop on 19R...118.4 (then again has troubles being heard. He's l/c here.)
freqhopping
Just now passing by me at 6k. 57-1487
Anyone have IDs for AE08AD, AE08BD, AE1368 ?
mdmonitor
Boston Center (ZBW)
Low:
134.0/317.7 DXR 19
123.85/269.2 PVD 34
128.1/351.7 PWL 06
134.3/256.9 SWF 05
High:
Tin,
Thnks---I'll add these to my list.
jsoergel
NASA 803 (G-III, N803NA) came from Buckley and departed a short while ago to Palmdale. Apparently they met up with NASA 801 (B200, N801NA) at Buckley (they went to Edwards).
Had AUTO 71 (KC-135) calling dispatch with no response after two tries, but then left the room - I'll have to check that one later.
Had something come in that I couldn't ID at 2043Z. No responses with Dayton, so I thought it might've been on UHF, but I did barely hear something with the tower - maybe just flying low with a weak radio.
That unidentified aircraft was NAVY JR 036 (C-20G). Did that come from Andrews?
NAVY JR 036 depared at 2139Z...I think I heard them readback direct APE, also may be deviating for weather.
HAWK 01 (C-21A, 84-0098?) arriving at Patterson...need confirmation on that tail. If it was the one from Andrews earlier, his radio problems are fixed now - 5-5.
1651 local (sounded like) LASKEY 11 flight of 3 at 13k inbound
Willow Grove on UHF Philly apch on the Cedar Lake arrival.
1740 TALON 70 inbound Willow Grove Philly UHF appch.
freqhopping
E-6B 407 was on my box a little while ago. Then I started messing with my computer and had to shut it down. Then I heard ZDC calling CORD-56 on guard and to come up on ZNY 132.525. I'm pretty sure that was it.
CBP helo N5204J is in Leesburg now for the hostage incident.
TinEar
Here's what I have for a log today after getting a very late start due to removing an old logging program and installing a new version.
NOTE: Callsigns are programmed by the aircraft crews and are often not updated for the current flight. So, take them with a grain of salt. Most REACH flights are correct as are JOSA flights. Tankers are very lax about programming their current call although some are correct.
N810AX RCH818 21:37:59.718 DC-10 OmniAirInternational
84-0092 JOSA923 21:33:34.843 C-21A 457thAS
92-3292 RCH370 21:21:48.781 C-17A 437thAW
05-5142 RCH5142 20:57:20.671 C-17A 729thAS/AFRC
84-0192 DUCE05 20:51:29.500 KC-10A 305thAMW
04-4136 RCH3126 20:30:08.890 C-17A 6thAS
164994 ------- 20:24:17.890 C-130T VR-53/AX
160048 CNV9866 20:07:07.843 C-9B VR-52
97-0043 RCH7043 19:30:06.500 C-17A 437thAW
95-0104 RCH5104 19:21:27.890 C-17A 437thAW
95-0104 ------- 19:11:39.500 C-17A 437thAW
96-0006 RCH371 19:10:45.515 C-17A 437thAW
89-1190 RCH809R 19:08:43.531 C-17A 437thAW
N524MC ------- 19:03:30.500 DC-10-30 AtlasAir
01-0040 ------- 18:59:13.500 C-40B 76thAS
96-0006 ------- 18:52:08.625 C-17A 437thAW
86-0020 ------- 18:45:43.906 C-5B 436thAW
164407 GOTO FMS 18:44:21.500 E-6B VQ4
166767 ------- 18:43:48.500 UC-35D VMR-2
165151 ------- 18:29:31.500 C-20G VR-48
62-3543 ------- 18:24:17.718 KC-135R AFRC/459ARW/756ARS
84-0118 JOSA124 18:23:44.500 C-21A 458thAS
78-23132 PAT 166 18:19:25.500 C-12 USARMY
164994 ------- 18:14:42.515 C-130T VR-53/AX
03-3113 RCH3113 18:01:13.500 C-17A 172ndAW/MSANG
166767 ------- 17:58:44.500 UC-35D VMR-2
163692 VV692 17:54:46.062 C-20D VR-1
78-23132 PAT 166 17:29:18.953 C-12 USARMY
84-0092 JOSA923 17:26:56.968 C-21A 457thAS
06-6168 RCH6168 17:22:37.984 C-17A 3rdAS/436thAW
84-0077 HAWK 01 17:18:10.671 C-21A 457thAS
85-1267 ------- 17:16:13.500 C-12T OSACOM/VA RFC
N270AX RCH298 17:05:00.718 DC-10 OmniAirInternational
87-0036 ------- 17:02:33.859 C-5B 60thAMW
85-0030 CABAL81 17:01:57.500 KC-10A 305thAMW
70-0454 ------- 16:59:41.500 C-5A 155thAS/TNANG
99-0402 S5159 16:59:04.515 C-37A 89thAW/99thAS
84-0209 CARMEN4 16:54:02.796 C-130H ANG/DE/142AS
166767 ------- 16:52:20.015 UC-35D VMR-2
70-0453 ------- 16:39:50.500 C-5A 433thAW/AFRC
74-1677 HAZRD 21 16:36:54.500 C-130H 317AG/40AS
86-0201 S5075 16:31:32.828 C-20B 89thAW/99thAS
84-0098 JOSA741 16:01:34.765 C-21A 457thAS
160048 ------- 15:58:55.515 C-9B VR-52
85-0030 CABAL81 15:56:56.078 KC-10A 305thAMW
95-0098 ------- 15:54:50.750 C-12R+ 2-228thAviation
------ ------- 15:52:57.515 T-38C NTPS
165962 ------- 15:48:18.500 T-6A NTPS
85-0042 HANK 42 15:45:30.500 C-130H AFRC/908AW/357AS
84-0125 ANG84125 15:41:56.875 C-21A 118thAS/103rdAWCT-ANG
84-0128 SPACE01 15:41:41.515 C-21A 118thAS/103rdAWCT-ANG
165926 ------- 15:37:11.500 T-6A NTPS
97-1944 PAT44 15:35:23.625 C-37A OSACOM/PAT
79-0104 ------- 15:31:25.156 A-10A 104thFS
165990 ------- 15:30:47.500 T-6A TW-6
57-1487 DECEE51 15:30:06.515 KC-135R AFRC/459ARW/756ARS
84-0098 JOSA741 15:14:45.781 C-21A 457thAS
158198 ------- 15:13:21.687 T-38C NTPS
63-7980 TROUT99 15:13:21.078 KC-135R AFMC/412TW/412FLTS
96-0112 ------- 15:11:00.500 C-12J USARMY
03-3113 E33113 15:10:11.156 C-17A 172ndAW/MSANG
84-0107 JOSA554 14:56:57.500 C-21A 311thAS
158201 ------- 14:54:04.500 T-38C NTPS
89-1182 MUSIC82 14:53:34.625 C-130H ANG/TN/118AW/105AS
78-0807 ------- 14:50:00.500 C-130H AFRC/911AW/758AS
165962 ------- 14:41:24.500 T-6A NTPS
62-3518 ------- 14:40:26.093 KC-135R AFRC/434ARW/72ARS
57-1512 CODY 01 14:38:00.656 KC-135R AFRC/459ARW/756ARS
161326 ------- 14:36:13.000 UC-12B Patuxent River
165959 ------- 14:30:06.156 T-6A NTPS
165601? ------- 14:25:51.515 T-45C ---
97-0401 S5179 14:22:59.500 C-37A 89thAW/99thAS
158200 ------- 14:22:45.781 T-38C NTPS
165151 VVJR036 14:16:40.156 C-20G VR-48
165985 ------- 14:16:31.015 T-6A TW-6
N138WA WOA8560 14:08:11.125 DC-10 WorldAirways
86-0201 S5075 14:07:45.500 C-20B 89thAW/99thAS
61-4856 ------- 14:06:34.640 T-38C NTPS
------ ------- 14:05:03.640 T-6A NTPS
62-3543 ------- 14:04:26.671 KC-135R AFRC/459ARW/756ARS
79-0104 ------- 13:59:56.500 A-10A 104thFS
07-7179 RCH7179 13:50:17.984 C-17A 3rdAS/436thAW
163395 ------- 13:47:23.703 EA-6B VAQ-209
00-1053 ------- 13:39:21.484 UC-35a1 PATD
84-0207 CARMEN2 13:32:08.812 C-130H ANG/DE/142AS
163691 ------- 13:27:56.734 C-20D VR-1
86-0020 ------- 13:26:37.718 C-5B 436thAW
02-0203 BOXER 45 13:15:30.437 C-40C 201stAS/DCANG
jsoergel
Had these confirmed at Patterson, with the exception of 62-3518; it could be MASH 64, but I can't confirm it. MASH 64 departed at 1605Z.
HAWK 01 departed Patterson as JOSA 144; asked Dispatch to pass on a departure time of 2302Z to TACC.
NAVY JR 036 dropping off 12 pax (1 code 6), no fuel needed.
DEECEE 51 was in the pattern for an hour before returning to Andrews
Unknown tails for today:
MASH 64 (KC-135R) - picked up aeromeds
MAINE 94 (KC-135R) - called in to ask if they could do pattern work tomorrow
AUTO 71 (KC-135R) - called Dispatch and Buckeye Control, no response at either
Also had VADER 06 (C-130H, 89-9106) stop briefly before departing direct PLUMM (usually a routing back to Youngstown: KFFO~PLUMM-TVT~KYNG). It's possible that they were dropping off aeromeds.
CitationJet
Northern Virginia
07.10.2009
1848Z 119.850 PT APP - PITT 07 - inbound vis. rwy 19R @ Andrews.
1851Z 118.950 PT DEP - MUSIC 82 - 700'-3000'-5000'-10 dir CSN VORTAC to 12000' QSY ZDC-Montebello 121.675.
1854Z 118.950 PT DEP - JOSA 941 - 1800'-3000'-5000'-11000'-17000' dir LDN VORTAC QSY PT A/D 118.675 then over to ZDC-Linden 133.550 to FL270 QSY ZDC-Moorefield 133.275.
1900Z 118.950 PT DEP - PAT 2401 - off Davison 800'-2000'-5000' dir GRUBY QSY PT APP 126.400.
1909Z 133.650 ZDC-Blue Ridge - DC 51 - FL296-FL250.
1916Z 118.950 PT DEP - TROUT 99 - to 14000'.
1916Z 141.550 GRIFFIN CP Andrews - HAWK 01 - dep time 1912Z.
1918Z 118.675 PT A/D - TROUT 99 - 17000' dir LDN VORTAC QSY ZDC-Linden 133.550 to FL190-FL230-FL250.
1920Z 133.550 ZDC-Linden - PAT 296 - 9000'-10000' QSY ZDC-Blue Ridge 133.650.
1922Z 118.675 PT A/D - DC 51 - 15.8-15000' dir WZZRD dir AML VORTAC.
1922Z 118.675 PT A/D - HAWK 01 - 17000' QSY ZDC-Linden 133.550 to FL270.
mdmonitor
Gold 71
0940 EDT- Gold 71 working with ZDC Sea Isle (133.125)--will be holdimg at FISSH intersection. At 0855 EDT also noted working on 347.2. This is MD ANG CP freq at Martin State but Gold 71 sounded like he was working some sort of ATC controller. At 0905 Gold 71 on 347.2 advises that the Mazdas won't be airborne for another 7 minutes.
At 0910 asks for direct Sea Isle in block FL150-170. Then QSY's to 127.7. Tells ZDC (127.7) they are meeting the fighters over Sea Isle in block FL150-170.
0939- four fighters working on 138.1--no calls noted--make that 6 fighters.
0944- Gold 71 tells ATC they will wait over Sea Isle for the fighters
0947- Gold 71 with fighters on 391.0---Mazda 21 flt--six fighters
JohnFB
Western Mass
NASA 806 (ER-2, N806NA) is up in the northeast on a mission this morning. Anyone in the area might be able to catch him, though it looks like he's headed home.
1640Z : NASA 806 wkg ZNY on 273.600 - chk in
1642Z : NASA 806 wkg ZNY on 269.100 - chk in
mdmonitor
Either or ...... probably Hebrew, but sounded a bit slangy like the way my inlaws speak.
Bottom line, it weren't English, any Romantic or Slavic language.
Prob Hebrew---Yiddish isn't spoken much any more by the younger Israelis. Yiddish is more of a hold over from the older generation whbo grew up in Germany
TinEar
Ron, the MAZDA flight leader is almost certainly one of our A-10 pilots from MTN. I recognize his voice. Nice catch.
Check 123.4 for the fighter interflight freq. Wow...these guys from MTN often just grab any freq they want but I've never heard them in this range. I was alerted to it by a fellow SBSer up the road 100 miles or so.
