Sticky Thread for MilAir
n3bxv
Severn, MD
Mark,
I posted the buttons below a few pages back. all these were recovered one busy evening. 282.275 appears to be an approach freq for Martin State, or that's what it was used for that evening, they pushed 4, then pushed 3 to the tower.
{edit to add} It's actually a BWI Approach freq paired with 119.0
Chuck
Ravens Button update
U-01 347.2 Raven Ops (guess based on common USAF usage)
U-02
U-03 297.2 Tower (Confirmed)
U-04 282.275 Potomac Tracon (Confirmed)
U-05 317.425 Potomac Tracon(Confirmed)
U-06 290.475 Potomac Tracon(once, needs confirmation)
U-07
U-08 281.8 (once, needs confirmation)
U-09
U-10
U-11 270.8 (Possible)
V-01 143.8 Raven ops (guess based on common USAF usage)
V-02
V-03 Tower (Guess based on UHF Usage)
V-04
V-05 142.3 Air to Air (confirmed)
n3bxv
Severn, MD
Alan,
Here's a pic of your USCG 6572, an HH-65C Dolphin...
Logs follow
1740 <358.85> Harass on Aux pointing out Atlantic City airport, Langley freq
1755 <271.0> Harrass 33, 34 apparently the replacements for the earlier pair "cant believe we ran that tanker out of gas"
1848 <249.8>GK " We're going to hit an A/R in 777 and then back to W-107"{edit - I heard "Triple 7", but it might have been Two Oh Seven, which makes better sense}
{2nd Edit, OK I'm not going deaf as fast as I feared,777 is correct Thanks Paul!}
1933 <121.8> PAt 825 inbound Andrews, Army UC-35 with codes on board. Unable to contact Command post Calling Andrews Ground, apparently get response from Mcguire ground as well.....Then calls tower 118.4, same message plus "talked to ground at every airfield on the east coast"
1939 <385.9> CRAB-51 calling Crab Ops
1944 <354.8> Bicep-11 enters Baywatch areas, A/A IS <138.3>
2000 <348.725> Angry-1 flight of four departs ADW, A/A <127.275>
2013 <139.9> Checks in with OPs
2015 Angry 1 Push to <254.3> ZDC COYLE very weak
2019 Angry 1 Push to ?55.??? (edit - I'm guessing 255.0 a GK freq)
2036 Bicep-11 ready to RTB <354.8>
2041 Bicep-11 with Devil Ops<261.0>
2120 Angry1 Flight (now three) checks in <354.8> will be in area 30 mins, still on AA <127.275> popping flares? Doing target Exercises and buddy lasing...
2145 <271.0> Harass flight still up there on Cap...
2157 <354.8> Angry 1 flt gettting clearance for the "tunnel" back to ADW
2159 <271.0> Harrass 33 with HUNTRESS 33,34 departing CAP. Tanker =Tanker 32
2201 <270.275> Angry 1 with Potomac TRACON
2207 <127.275>Angry 1 Gear down
2210 Angry flight "push 4" <349.0> Tower
2214 <270.275> Cobra-20 with ATC descending then to ADW Tower <349.0>, Anyone have a clue who this is?
2229 <118.4> Venus-1 Landing
Not to argue you with you Al, but if you take a right turn from the Coyle VOR and Shipbottom NJ, My sectional chart shows the W-107 Giant Killer Area...
cipher66
ARTCC DB Manager
Highland, IL
AR777 is located in W-105 off the coast of Cape Cod (for some reason it's not listed in most guides). Pri: 228.000 Sec: 288.000. This is normally a Giant Killer or Huntress track for air defense ops, but I have heard channel missions use it once in a while. Usually I hear NJANG F-16s and MAANG F-15s on this track along with AWACS a/c.
Paul
TinEar
Glen Burnie, Maryland
The Combat Air Patrol over NYC might just continue for several days. The United Nations World Summit begins tomorrow and runs through the 16th. 160 world leaders will be in NYC - with several of them having already arrived. I wonder if Langley got tagged for the whole thing. Paul, let us know if any of the MA or CT units get the call.
Before I forget...thanks Paul. Guess how I found that 271.0 HUNTRESS freq?
And thank you too Chuck for that picture. That's the guy.
2003: DC-ANG up on 127.275, ANGRY callsign, flight of four. (Have the ANGRY flight on the webcast for now)
ANGRY leader goes to SOF 139.9 and announces take off time "on the hour." Guess he forgot to do that earlier.
NOTE: Chuck, you can have the log tonight - I'm busy with some other things. If I hear something new I'll note it - otherwise it's all yours. Of course, that's if you wish to.
JackTV
Tin,
Sorry I did not respond had to go to work. I only heard the 1 flight on 41.95 earlier in the day. Right now I am picking up a controller ...I guess on 353.5. It sounds like he might be up North somewhere. Any idea who it is??
Jack
8:47- Angry just pushed 266.5 for refule
TinEar
Nope, don't know what 353.5 is without some research Jack.
Chuck, that ZDC Washington Center 254.3 freq the ANGRY flight used is in Shipbottom NJ so they went north for their exercise which should rule out the GIANT KILLER area. It's Area G (High) which covers 24-33,000 feet.
n3bxv said:
Mark,
Chuck
Thanks Chuck for that,I thought it may be a apprch freq as they seemed to be headed into Martin State.
Also I can confirm 290.475 as Potomac appch from Annapolis area as had that in scanner from back when Blue Angels were doing Navy grad show back in May and had hits on it.
TinEar
Mark, the question that's open is whether it's U-6. The Potomac approach ID is golden.
So is your W107 golden Chuck. I keep forgetting that part of the GK area. It's sort of like always thinking Virginia signals are from the south when a lot of what we hear on the police/fire freqs are due west.
n3bxv
Severn, MD
This callsign seems to have been associated with VAQ-209 in the past. Are they still at Andrews?
n3bxv
Severn, MD
1908 <319.4> Jedi-43 with Mcguire Cmd Post inquiring on the status of Hoser-11 for their refueling in AR777
1919<228.0> Jedi-43 with ?? Setting up AR on 777
Sorry Alan, I was taking care of somethings around the house. The Jedi Callsign was also previously used by Mcguire C-141s, so it may have carried over to the C-17s there.
1957 <348.725> Ravage-1 Flight of 3 Climbing out of ADW A/A <127.275> Going to Goggles
2000 <281.4> Ravage-1 flight with ATC, Push to <354.8> One aircraft having UHF radio problems
2002 <354.8> Checkin with Baywatch, Cancel IFR, will be in Airspace for 35 mins
These 2000hrs missions are getting predictable! They must be trying to burn up this FY's Fuel allocation:)
2009 <135.725 > Baton-55 in the GK
2010<254.300> Tiger-11 Direct Shaw
2012<348.725> another flight of 2 (ANGRY) departing ADW, Direct Patuxent push <281.4>
possible A/A <143.15>
2012, Angry-1 with ATC<281.4> Tiger-11 checks in too(CAP birds from NYC rtbing to SHAW)
2028 Bicep-11 with(ny) Center<254.300>request direct ?HUGeno? then <307.25> AA<138.3>
2033 <354.8> Ravage departing 5 mins, up towards Sea Isle (talk on AA about Tanker)
2036 Ravage 1 Flt departs PAX<354.8> Bicep-11 Flt to <323.3> ATC
2037 Bicep-11 to <323.3> "Going to Syracuse 1, 2, and 3 MOA" and then back to ACY
2039 RAvage with ATC on <256.8> and with Ops <139.9> checking tanker status push <285.4>
2041 <266.5> Boom Ravage-1 calls Steel-61
2034 <364.2> Nappy-85 calling Huntress(Could have been Backy, I was busy with the fighters)
2045 <255.0> Ravage with GK, entering W-107, refueling with STeel-61, Acknowledge C130 traffic in area(probably Baton-55)
<139.9> RAvage with SOF
2048 <285.4> Angry Flight w ATC setting up for AR as well.
2051<285.4> Arrow/Aero-21 calling Washington
2052 <354.8> Angry-2 with PAX(another flight) AA<143.15>
ARROW-21 here too AA<138.25>
2054 <255.0> Angry-1 Flt now with GK
2057 <135.725> Baton-55 with GK preparing to depart
2100 <228.0> Backy-85 calling Team 39, .... on AR Primary
2107 <255.0> ?Ravage? departing GK airspace
2111<354.8> Arrow-21 Orbiting for 20 more minutes
2112 <285.4> Ravage returning, with ATC
2116 <139.9> Ravage to Senate, checking on ramp freeze
Took a break to answer the phone...
2130 <127.275> Ravage 1 practicing Intercept Procedures
2141<311.0> Steel 61 to Steel Control 20 minutes out
2142 <354.8> Arrow 21 Flight ready to RTB but..........
2144<143.15> Ravage to Angry ... Still Ramp Freeze
2155 <261.0> Aero-22 with NJ Command post
2200 <285.4> Angry 1 with ATC Holding at Nottingham
2205 <319.4> Force-87 with McGuire Command Post
2207 <360.7> Angry 1 with ATC
Victor 7 = 143.15 This is different than posted. Confirmed X2
2211 <338.2> Angry Flight with Potomac TRACON
2214 <307.25> Bicep-11 request direct ACY
2220 <335.5> ADW App <234.8>SOF Much talk about getting cleared into ADW
2222 <270.275> Ravage Descending ...
2224 <338.2> Angry ready for the letdown and approach
2227 Ravage "push 4" Angry De-Goggle
And everyone lived happily ever after....
TinEar
Nevermind Chuck..I got here sooner than I thought.
Just a mention - The NYC Combat Air Patrol is now being done by TIGER 11/12 with TANKER 37. The TIGERs may be from the 115th Fighter Wing of the WI-ANG in Madison or the 79th FS at Shaw AFB SC.
TANKER 37 is probably from Pease AFB NH based on the wx report he asked HUNTRESS to get for him for PSM. They are still using «271.0» with HUNTRESS.
Note that the JEDI aircraft that Chuck mentions above could also be from the WI-ANG or any of several locations according to the callsign list.
Today was another busy day with all the ANG units within hearing range active - MD (COLT) -- DC (ANGRY) -- NJ(DEVIL & BANGER -- PA(FLYER) -- VA(SLAM & BASH) plus Langley's F-15s and Navy F-18s. Those of you that listen to MilAir during the day were swamped I'm sure, as I was.
1957: DC-ANG up «127.275» RAVAGE
2000: BATON 55 (EC-130, 193rd Special Operations Group, PA-ANG, Harrisburg) enters the GIANT KILLER area «135.725»
2005: VA-ANG active Command Post freq «141.6»
2010: Two more DC-ANG fighters up, using «143.15» ANGRY
2030: NJ-ANG up «138.3» BICEP
2037: STEEL 61 flight in the area (KC-135 PA-ANG, Pittsburgh) Might be refueling the DC birds.
2042: Have a BACKY 85 Heavy (KC-135, Seymour Johnson) checking in with HUNTRESS on «364.2»
2045: The RAVAGE F-16s are indeed trying to hook up with STEEL 61 for refueling. But they keep seeing a C-130 - the BATON flight.
2053: Refueling freq is «266.5»
Dank
MD
Alan, I'm listening to the DC ANG on your website right now. This sound quality is great compared to what I currently have with only an indoor antenna. Do you have an idea where they are compared to the BWI area?
Dan
JEDI is also popular training callsign for McGuire C-17's.Sort of like BOLAR and HAGAR for Dover C-5's.
TinEar
Wish they'd space this activity out...have both RAVAGE and ANGRY flights attacking targets as are the NJ guys...three freqs, two ears...wish I could get them all on the broadcast.
Another ramp freeze at Andrews began at 2140 to last for up to 45 minutes.
ANGRY and RAVAGE flights stuck in the air until it's over.
n3bxv
Severn, MD
This is pretty crazy this evening. Angry, Ravage, Baton, Bicep, Steel, Jedi, Hoser, Backy.....guest appearance by Tiger on the way home,
Who's Arrow/Aero? Any idea?
And there's my Answer -- Aero-22 with NJ Command post <261.0> Thanks for your input as well, Alan.
TinEar
New Jersey F-16s...I still like AERO for the call...that first syllable sounds like "AIR" to me.
ANGRY flight might get low on fuel before the ramp freeze is called off. 4500 pounds left on ANGRY 1 and he's got less than 2. His flight is going to circle over Nottingham.
2204: NJ-ANG active again...BICEP «138.25»
2205: RAVAGE flight down to 3.2 and 3.4 K fuel.
2210: ANGRY flight will land first - lower on fuel. (But changed that later)
2213: Now they say there is an emergency in addition to the ramp freeze at Andrews. They may have to use the Beltway for landing. <g>
Think they are setting up with Patuxent for an alternate landing site if necessary...just checked in with Pax on 120.05
They'll be landing on runways 19L & R.
2220: ANGRY switched to tower 349.0 and got permission for both flights to land.
Unusual that RAVAGE contacted SOF on UHF...normally they only use the 139.9 freq.
2230: RAVAGE flight on the deck «349.0»
2234: ANGRY flight about to be on the deck.
A real busy night...Good listening..
261.000 is Uniform 1 CP for some Atlantic City F-16's. Don't hear that one too often but L+C tonite.
Now hearing RAVAGE inbound on 234.800
n3bxv
Severn, MD
Great night to listen, planes all over the place!
Tonight's update ----
Victor 7 = 143.15 This is different than posted on the first page and in the RRDB. Confirmed X2
{edit} I haven't done it yet, if you're going to submit some others go ahead and add this ..
TinEar
I thought I had already submitted that V-7...originally it was both 139.15 and 143.15 and then settled on 143.15
Have you already submitted it Chuck? If not, I'll add it to something else I've got.
Apparently, the DC-ANG was going to fly tomorrow night also. RAVAGE flight mentioned that they probably won't though because of the weather coming our way.
[Edit] Will do Chuck...my memory is obviously shot. I remember thinking about submitting that one a couple of months ago and must have just totally forgotten about it. CRS.
And great job tonight logging all those freq changes as they hopped around the spectrum.
And Paul...if you're reading...I see Otis Air National Guard base has been spared and will not be closed as originally thought. Way to go! Happy listening.
Alan
