The BICEP F-16s (NJ-ANG) were a flight of three (BICEP 11/12/13). Upon leaving the BayWatch Pax River area on «354.8», they contacted DEVIL Ops on «261.0» for the ride home to Atlantic City. They called for about five minutes before they were heard by Ops - a distance problem I would assume.
The CAP is still flying as mentioned above, with primary on «228.9». TANKER 08 is the refueling aircraft. HARASS 53/54 are the current pair of Langley F-15s flying interdiction missions for wayward aircraft should they appear where they don't belong. Chat between HARASS flights - going from and coming to the CAP area - are being done on «357.1». The scan found this immediately now that it's part of the rotation. Thank you Chuck. Entry and departure from the area are being done on GUARD DOG/Washington Center freq «288.35»
How about some light reading? The following URL gives some insight into scrambles out of Andrews. Disregard who prepared this report. That part is not important. Within this report are some PDF attachments that display copies of tower logs, officially called "Daily Record of Facility Operation" for Andrews and National. During the scramble described in this report from the summer of 2002, they use the callsign BRAVE which is still in use. There are some nuggets of information here that you can use for future scrambles.
http://www.fufor.com/case020726/020726_AndrewsFoiaResponse.htm
Around 1530, VA-ANG F-16s active on «141.825/141.875» Callsign BASH
1540: HARASS 55/56 on the way to take over the CAP.
1541: TANKER 08 ready to RTB when 09 arrives but HUNTRESS doesn't have 09 on freq yet.
1544: HARASS 53 contacts 55 on «324.0» and tells him to make 15 Aux «228.9». 55 then comes up on that freq.
THE END - Off to fight the yardwork wars.
