1207: WILD flight (DC-ANG, F-16, Andrews AFB MD) active on «127.275» Flight of two.
1210: WILD flight with ZDC-Ship Bottom NJ on «254.3»
1220: Another DC-ANG flight airborne, using «143.15» Flight of two. Callsign SCARY
1222: WILD flight pushing 337.225 «127.275» (But I never hear them there)
1223: SCARY flight to ZDC-Ship Bottom NJ «254.3» FL210...then "switch to scratchpad 360.7"
1228: WILD flight in air combat exercise on tac «127.275»
1232: WILD flight reports seeing a C-130 off to their right «127.275»
1232: SCARY flight to GIANT KILLER «255.0»
1233: SCARY "push 337.225" «143.15»
1234: SCARY flight checks onto freq «337.225» (As many times as the DC-ANG F-16s have used this frequency lately, they have not made it a pushbutton. It's always mentioned as a specific freq to switch to rather than a U button push.)
1244: WILD and SCARY heard on their tac freqs - but weakly on and off until this time. Never have heard either flight on the 337.225 freq other than when SCARY checked in there. Not sure if they fly low when they use that freq or why I seem to have trouble hearing it. It's the only UHF freq I seem to have a problem with so I'll go with the "too low to hear" theory.
1248: OMAHA 1 (Customs) to THOR on «282.425» "Could you all my supervisor, Chris (omit) and tell him I'll be on the ground in 20 minutes?" He does, everyone's happy.
1250: HOCUS 91 to IRON Ops on «357.1» with mission report.
1303: SCARY flight just coming into hearing range again on tac «143.15»
1304: And the WILD flight reappears on their tac «127.275»
1307: WILD 1 & 2 both report Code 1 status...flight leader clears 2 to go to SOF with mission status and to also get the weather. «127.275»
1309: WILD flight with ZDC-Kenton DE on «277.4» at 11,000
1309: WILD 2 back to tac to report he has ATIS Zulu «127.275»
1311: OMAHA 1 repots he's sixth in line for landing and on final «282.425» (His nest is at Reagan National)
1314: SCARY flight with ZDC-Kenton DE «277.4»
1320: WILD to Andrews Tower on «349.0» for landing
1326: SCARY flight to ZDC-Kenton DE «277.4» reporting at 11,000
1328: SCARY 1 & 2 both report Code 1...flight leader clears #2 to give mission report to SOF and to ATIS for wx. «143.15»
1330: SCARY 2 to SENATE SOF on «139.9» gives mission report with ordnance expended and Code 1 info for both.
1331: SCARYs both back on tac «143.15» where flight leader says, "push 254.35." ...I'm not sure who that is. Anyway...they come right back to tac within 30 seconds where they agree information Zulu "is kind of screwed up."
1335: SCARY 1 points out to 2 where his house is near the marina on that peninsula off to the right. Near enough to the water to hear it from his house. "Cool," responds his wingman. «143.15»
1337: SCARY flight to Andrews Tower on «349.0» where they report in as "a flight of two Capitol Guardians"....flight levels at 1600 and 2500. They'd like to do an SSO if possible.
1339: SCARY flight reports climbing "right through this gap" «143.15»
1340: SCARY flight reporting "high key" and "low key" (Dunno what that means) «349.0»
1341: Pair of Langley fighters doing air combat on tac «276.675»
1341: SCARYs gear down and landing «349.0»
1343: Last SCARY on the ground. «349.0»
1345: ???? 21 with GIANT KILLER on «233.7» mentions being over Cherry Point.
1358: VOLLEY 21 (Unknown) checking in at 12,000 with ZDC-Patuxent MD on «281.4» cleared to 23,000. Flight of two. (He called several times before receiving a reply and the callsign was very clear.)
1402: VOLLEY 21 flight cleared from FL230 to 260. «281.4»
1404: VOLLEY 21 flight cleared to FL280. «281.4»
1404: U/I with GK on «233.7» mentions wanting Mode 3 for three flights that he'll be working with - the only one I caught was SPEEDO (F-15 Langley)
1406: VOLLEY 21 changes to ZDC-Whaleyville VA on «327.8» checking in at FL280.
1412: Raven Ops on «347.2» talking to aircraft on the ground...mentions flight of four.
1414: FURY 11 (F-16 VA-ANG Richmond) with ZDC-Green Bay Va on «269.4» checking in at FL210
1415: FURY 11 cleared to 230 and cycling Mode C. «269.4»
1417: FURY 11 level 230 «269.4» (We had Fury 01 this morning on ARTCC freqs)
1419: A-10s from Martin State off the ground and operating on tac «142.3»
1421: A-10 pilots chatting on «142.3» sounds like one pilot is a visitor...he's asked if he ever gets to fly over water and the answer is no. This might be one of the SANDY pilots that came in from Willow Grove yesterday. The visitor also wants to know if they can talk to Dover "from here"...the home towner says in about 5 minutes. Also warns him about big towers in the area...watch the one ahead with the light on it. Still no callsigns heard since they took off.
1423: The Martin A-10s fade out on tac «142.3»
1428: COLT 1 (MD-ANG A-10) calling Dover on «257.875» (Must be our guys from above)
1430: DRAGON (Langley) flight into GK's area on «238.1»
1433: MAPLE 11 (F-16 VT-ANG Burlington) with ZNY-North Mountain PA on «273.6» FL270
1435: MAPLE 11 to ZNY-Elk Mountain PA on «298.9»
1437: U/I callsign, IDs as C-17, British speaker...arriving Andrews 1850Z, A-1, no pax or cargo, needs 30,000 pounds of fuel, needs crew transportation and parking spot.
1440: SANDY 1 (A-10 PA-ANG Willow Grove) with ZNY-Philipsburg PA on «338.3» (Transmission blocked by a loud mouthed C-12 going into Andrews)
1441: SANDY 1 direct Lancaster, then ?TRYST?, then MTN (Martin State) «338.3» (More Willow Grove A-10s to Martin State)
1443: SANDY 1 to ZNY-Joliet NJ on «239.05» reporting at 14,000
1442: SANDY 1 leaving 15K for 14K «239.05»
1446: SANDY 1 leaving 14 for 13,000 «239.05»...leaving 13 for 12,000 at 1447....slowing to speed 250 at 1449..."push 7" at 1450.
1451: SANDY 1 and 2 come up with Raven Ops on «347.2» where SANDY 1 reports as Code 2 and SANDY 2 as Code 1.
1453: WARHOG 1 (OA-10 PA-ANG Willow Grove), flight of two, with ZDC-Bucks Elbow VA on «284.7» at 18,000 ...leaving 18 for FL220 a minute later...
1454: WARHOG 1 with ZDC-Bucks Elbow VA on «263.1» at 22,000
1456: SANDY 1 & 2 with Martin Tower on «297.2»
1458: SANDYs setting up over Hart-Miller, runway 33 for initial «297.2»
1501: SANDYs over the numbers...full stop on 33. «297.2» (Slightly different terminology from these Willow Grove A-10s upon landing than our home station guys. Meanwhile, it sounds like the COLT flight that left earlier went to Dover. It's getting difficult to keep up with this bunch at Martin State.)
1503: JOSA 584 to SAM Command on «378.1» landing Andrews in 15 minutes, tail #40090, is A-1, has 1 D/V on board-an R-4, releasing 4 seats on the outbound estimated for 2100Z.
1505: TESTER 04 with BayWatch on «354.8»
1505: Northrup Gruman flight 61 reports airborne «123.225»
1524: CHALICE (E3B Tinker AFB OK) reports he's going home and thanks GIANT KILLER for the work. «233.7» This is the one from earlier that mentioned he'd be working with three different Langley flights including SPEEDO.
END OF REPORT...think I'll follow CHALICE.
P.S. COLT flight of two coming home...chatting on tac «142.3» and reporting both Code 1 to Ops on «347.2» around 1530. This is still the visitor (newbie as he describes himself) with the vet teaching him procedures as they approach Martin State. Talking about people they know and places they've been. Newbie also wants to know if Approach into MTN is Patuxent and is told it's Potomac. So much to learn...so little time. This new guy is just too funny. Swears they are going too slow on their approach. They are doing 250 but he swears it feels like 150 (knots). Apparently, they make their approach much faster and not so protracted as here at Martin State. He says he's afraid of heights and they're going too slow...feels like he should have his gear down. This is all said with a "smile" in his voice. This makes me wonder what these Guard pilots have to do when their unit is moved such as the promised move from Willow Grove to Martin State. Commute? Move and give up civilian job? Or give up their Air National Guard position? All those choices are difficult.
