TinEar
1845: Have had a couple of fighters chatting on «139.9» for the past 15-20 minutes. I don't think they are DC-ANG F-16s that normally use this freq. It sounds more like deploying aircraft or someone in transit and is fairly weak from my location.
1854: REACH 8226 calling HUNTRESS on «364.2» (Had this aircraft in the 1400 hour going into Langley.)
1855: REACH 8226 asks HUNTRESS for a sweet/sour check...gives his Mode 3 as 6512 so HUNTRESS can identify him on his scope. «364.2»
1901: Raven Ops yakking with aircraft on the ground at Martin State «347.2» Get ready.
1904: And here they are...pair of A-10s up on tac «1142.3» Callsign AXEMAN
1906: AXEMAN flight reports back to Raven Ops they were off the deck on the hour «347.2»
1910: AXEMAN flight push 12 and comes up on ZDC-Kenton DE «277.4» requesting clearance to 5002
1914: AXEMAN to ZDC-Sea Isle NJ on «285.4» checking in
1933: Three ship flight with Potomac TRACON on «317.425» Didn't hear the callsign. AXEMAN flight??? Nope, it's a RAVEN flight of three A-10s from MD-ANG Martin State.
1937: Potomac tells RAVEN flight to change to Dover Approach on 257.875 and that's exactly where they come up and report they are heading for Atlantic City.
1944: Warren Grove Range active on «283.1» Little doubt that RAVEN flight is there but I didn't follow the AXEMAN flight out of the area so I don't know where they went. (Per carbineone above they are at Warren Grove also.)
1955: DC32 (KC-135 756th ARS Andews AFB) to LIBERATOR on squadron freq «351.2» asking about ramp freeze at Andrews.
2014: Martin State A-10s on tac «142.3» again and being heard rather well on the Warren Grove «283.1» freq...they must be higher.
2019: AXEMAN flight 10 minutes out from Martin State with Ops on «347.2»
2020: U/I (See below) aircraft with Phillips AAF on «126.15» reported he just had a massive bird strike and must return to Harrisburg.
2024: BATON 55 (EC-130, 193rd SOG, PA-ANG Harrisburg) to Baton Ops on «395.1» 15 minutes out...negative on engine shutdown, A-2 (This is the aircraft that was at Phillips with the bird strike)
2027: BATON 55 reports co-pilot can't see out his windshield. «395.1» Guess that's where the bird strike was.
2036: Warren Grove Range still active «283.1»
2106: DC 32 to TIGER Ops reports hitting a bird...says it was not over the airfield so the bird is not on the runway. «351.2» What's up with these bird strikes tonight?
2113: RAVEN, flight of three A-10s coming home to Martin State...14 miles out, straight in approach for runway 33. «297.2»
Carbineone: Both the earlier MCGRUFF flight and now the CHILLY flight (the one with the emergency) are reported using 138.05. Is it true that both Barnes and Bradley use that for a tac freq that you know of? I'm thinking that CHILLY is from Barnes but I'm not entirely positive of that...they both might be from Bradley. To make matters more difficult, some of the New England listeners use CHILI and some CHILLY.
Chuck, yes, it is constant on that freq (243) for me. I've had it locked out for months because of it. Oh, and I was running search in the 300-340 range the whole time before and after you reported the CRAB C-130 with Martin State and heard nothing. Guess I'll move the search a bit higher and see what I get.
Going lower rather than higher...searching 270-300 for the CRAB Ops freq this time.
Frequency 280.2 becomes of interest...heard a couple of transmissions from military aircraft...not nearly enough to identify it...found in search for CRAB Ops but have no idea if it's associated. Putting it into scan rotation for possible ID.
Re 280.2: Unfortunately, no Chuck. Heard the same conversation you did I guess but not enough to reach an opinion on it. Oh, I guess you mean is the unit still there....don't know for sure. Speaking of Navy...did you catch that log at 1511 above with the Navy freqs given out by Andrews?
