1117: GIANT KILLER's «238.1» active
1118: Langley's SPAD Ops active on «364.125»
1127: Copter 280GS with Phillips AAF on «126.15» transit to the east.
1129: Aircraft 406 to Shadow Maintenance at Pax River NAS on «310.15» says he's off the deck and may be back later.
1158: TOIL 39 (C-130, 357th Airlift Squadron, Maxwell AFB AL) to Dover Dispatch on «269.125» IDs as a C-130 about 25 minutes out, has two pallets to download and wonders if they have a "Loadway" or a forklift. Says he'll return to Maxwell after downloading.
1203: Navy 691 into BayWatch area R4006 for 30 minutes and wants altitudes 17,000 down to 3,500. Entering the area at 14K. «354.8»
1212: BOLAR 70 (C-5, 3rd Airlift Squadron, Dover AFB DE) to Dover Command Post on «349.4» reports he finished his air refueling training and will be landing at 1330 local.
1214: Langley's tac freq «238.825» active...pair of u/i fighters.
1217: More fighters on Langley's tac «252.775» with one of them having a radar problem.
1221: ?DECAF? 21 into GIANT KILLER's area on «238.1» (These are the Langley fighters heard on the tac freqs reported above.) It's a flight of four aircraft
1222: DC 21 (KC-135, 756 ARS Andrews AFB MD) approaching Andrews and will be doing a final stop by 1300.
1222: ?DECAF? 21 flight to GK's «391.2» and «373.1» for ops...they'll be doing some 2 vs 2 air combat exercises
1227: Above fighters to Langley tac «228.45» to lay out the mission.
1233: Looks like those fighters gave up the 391.2 freq and are now working GK's «312.3»
1236: JOSA 284 to Andrews Command Post on «378.1» arriving in 15 minutes and will park on 10 row...wants to ensure transportation has been arranged for his pax and the air crew.
1238: PAT 674 calls Andrews on «378.1» with no reply so tries «141.55» and makes contact to report 10 minutes out and is a C-26. He says he's picking up a D/V Admiral to take to McDill AFB FL and just wants to let him know he'll be landing in 10 minutes.
1245: HOOPER 61 flight (F-15 Langley) into GK's area on «238.1»
1248: RACK 41 flight (F-15 Langley) into GK's area on «249.8»
1254: U/I aircraft IDs as a single F-16, 10 minutes out to Langley Command Post on «251.25»
1255: JOSA 869 reports off the deck at Andrews at 1754Z «378.1»
1302: Fighter tac freq «138.0» active...might be our SPIDERs again (F-16, ND-ANG Fargo) out of Langley.
1305: The above IDs as a single F-16...talking to ground. «138.0» (See item at 1254: wonder if this is the single F-16 that reported earlier going into Langley. Last transmission was very weak.)
1324: Activity on Bollen Range «237.2»
1326: OMAHA 3 (Customs) from THOR on «282.425» "Just had a call from CRAB SHACK that they would like you to contact RENEGADE on 260.9 for a "sparkle" (red/green laser warning system around D.C.) test on your way back to base." (OMAHA 3 either too low or too far away to hear - and so I don't.) (Had a receiver on 260.9 for the next 15 minutes and heard nothing - as expected.)
1341: JOSA 813 to Andrews on «141.55» 25 minutes out, tail #40119, no D/Vs, no pax, need 3K fuel, parking spot....and is given 10 row.
1344: U/I fighters on «142.45» mention BALKY which is the Bollen Range controller. It's a flight of two aircraft. (This may be the UGLY (A-10 PA-ANG Willow Grove) flight that carbineone mentions below.) Nope, it isn't. See next item.
1345: CADE A-10s (PA-ANG Willow Grove) are the fighters on «142.45» They are working the Bollen Range.
1351-55: REACH 1712 calling Dover Command Post several times with no reply on «349.4»
1355: REACH 1712 makes contact with Dover...reports 10 minutes out, is a C-130, Tail #92-0547, is A-1, has 5 pallets to offload and no pax. «349.4» (C-130H per tail number lookup)
1400: VA-ANG F-16s in the air on tac «141.875» flight of at least three and maybe four. Callsign SLAM
1403: SLAM 31 flight into GK's area on «238.1» and reports he'll be MARSA with RUST 71 (F-15 Langley) for the next 25 minutes.
1406: RANGER 88 (poss C-12 VIP ferry acft) calling Andrews Dispatch on «372.2»
1409: SLAM flight leader "push 292.3" while on «238.1»
1414: TESTER 15 into BayWatch area on «270.8»
1415: OMAHA 3 (Customs) on «165.2375» tells ground to let him know where he should be and wants to know if they're looking for anything special. (This is a patch onto this freq)
1416: SLAM flight on GK's «292.3» for ops
1417: OMAHA 3 still on «165.2375» but it's a lousy patch that keeps cutting in and out. He says he'll let them know when it begins to sparkle (Again, a test of the red/green laser warning system apparently. This must be the test we heard about earlier - see item at 1326 - that was supposed to take place on 260.9. It might be originating on that freq but because OMAHA 3 is so low and distant, I'm just not hearing it there but it's coming through okay on the patch on this freq. Ground station must be RENEGADE as mentioned earlier.) Ground station tells the helo to slow way down, face 070 degrees toward the camera. They are trying to turn the system on. At 1422, ground tells OMAHA 3 he can move in a little closer and then the patch starts cutting in and out. OMAHA 3 is heard saying he is talking to the tower too.
1424: OMAHA 3 reports he doesn't see a thing. The ground station starts talking but cuts in and out as the patched signal goes crazy. OMAHA 3 says he'll head back in. «165.2375»
NOTE: The activity on 165.2375 is in FM mode. The aircraft are using AM mode but the patched signal is in FM.)
1426: OMAHA 4 (Yes, he called 4, not 3) called by ground station with no reply heard on «165.2375» (Because this is such a lousy patch, I don't know how much of this I'm not hearing.)
1430-31: OMAHA 3 and ground talking back and forth but the patch is cutting in and out so much that I can't even get the gist of the conversation. «165.2375»
1432: SLAM flight back to working tac «141.875» (Never did hear the RUST 71 flight they were supposed to be MARSA with in GK's area.)
1436: SMOKY (or SMOKEY - both spellings are valid) 99 (C-21, Petersen AFB, Colorado Springs CO) to SAM Command on «378.1» reports departed Andrews at 1930Z and wants that passed on.
1445: WARHOG 1 (OA-10 MD-ANG -maybe) with one of the ZDC freqs (didn't look fast enough) reporting out of 19.2 for 260.
1445: VENUS 22, home station aircraft, arriving Andrews «378.1»
1450: VENUS 22 to SAM Command again on «378.1» to report he's a home station aircraft arriving at 15 after the hour, has three writeups (all minor), needs parking spot and crew transportation for four...gets 7-D for parking.
1455: TESTER 25 (US Navy Test Pilot School, Patuxent NAS) with BayWatch on «354.8»
1457: TESTER 25 on Pax River «256.5» talking to a u/i wingman.
1500: WARHOG 1 with ZNY-Big Flat on «270.3» sent to freq 253.8
1502: WARHOG 1 again with ZNY on «270.3» and says 353.8? (Correcting above freq I guess)
1503: TESTER 25 on «256.5» reports a loud bang and then a big vibration...wingman (TESTER 26) coming in for a look.
1505: Wingman tells TESTER 25 he doesn't see anything missing, nothing hanging where it shouldn't be hanging, etc....25 says he'll burn off about 1000 pounds (of fuel) and then RTB. 25 then tells Pax he and TESTER 26 are done with this freq and want another. «256.5» It appears 25 has a nose gear problem
1514: TESTER 25 to BayWatch on «354.8» says he's 8-10 minutes from landing. Wants ground to contact the tower to see if they want 25 to land on a non-duty runway because of his nose gear problem. (I mean you can't go leaving a mess on the active duty runway, can you? If you're gonna splat, do it somewhere that's not going to inconvenience anyone else.)
1517: TESTER 25 still on «354.8» and sounding calm and collected so apparently the problem is not overly severe or else he's one cool character...he's ready to make his approach.
1518: TESTER 25 has field in sight «354.8»
1520: TESTER 25 thanks ground controller for his help «354.8»
1521: TESTER 25 on Pax River Tower freq «344.4» announces full stop landing on runway 6. (And that was the last transmission I heard from him.)
1541: TESTER 26 to Pax River Approach on «250.3» "5 out"
1552: JOSA 625 (female) to Andrews Command Post on «141.55» reports as a home station C-21, tail #40075, arriving in 25 minutes, downloading an R-4 plus 1 duty pax. Mission complete upon landing, is A-1 and requests parking spot...gets 9 row.
1555: JOSA 813 (female) to SAM Command on «141.55» twice with no reply.
1600: It's that time again....END OF REPORT
