1032: Northrup Grumman test flight activity...two aircraft on «123.2» and then they enter BayWatch Pax River area using «270.8»
1039: TESTER 09 with BayWatch on «354.8»
1045: BOLAR 71 (C-5 Dover AFB) to Dover Command Post on «349.9» trying to work out an earlier time for some event (I think refueling) and suggests 1730Z as a time to do it.
1049: Pair of tankers chatting on interplane freq «139.875» suffix 53 and 54 heard. One mentions a route of VCN-VINSE-AIR (spelled out phonetically). One of them also is talking to NY Center on 121.02 and the other to Washington Center on 125.45 according to their chat.
1059: DC 52 (KC-135, Andrews) reports to LIBERATOR that he's airborne. «351.2»
1100: U/I aircraft on Pax River «264.15» with some kind of problem. He's going to drop his landing gear and have someone fly under him to check for whatever he thinks is wrong. (They must have changed freq because I heard no more here.)
1104: WILD 1 (DC-ANG F-16, Andrews) with Potomac TRACON (Reagan) on «348.725» cancelling IFR. (WILD appears to be a single ship flight)
1105: WILD 1 to ZDC-Patuxent MD on «281.4» reports direct Pax River.
1106: TESTER 15 (female driver) with BayWatch on «270.8»
1106: WILD 1 to BayWatch on «281.8» where he's sent to «279.8» says he's going into R-6609 and wants the maximum altitude he can get cleared for but then announces he'll be working 3-250.
1111: TESTER 08 and TESTER 24 working BayWatch on «354.8». Believe 08 was the guy with the landing gear problem above. Sounds cool now. Says he's going to burn off some fuel and then land.
1112: Pair of DC tankers chatting on squadron freq «351.2».
1118: TESTER 18 with BayWatch on «354.8» Vertical maneuvering.
1118: DC 51/52 chatting again on «351.2» 52 wants to know if 51 is going down to FL210...he is.
1119: SALTY DOG 535 with BayWatch on «354.8»
1122: DC 51 and DC 52 are trying to meet up. They also agree this freq «351.2» is "Comm 1, Button 10"...52 mentioned he had tried button 3 but got no reply. I didn't hear him anywhere else so can't identify that freq.
1123: TESTER 08 tells BayWatch he keeps calling him TESTER 24 so does he want to change his call from 08 to 24. «354.8» (I think he was just being sarcastic and ragging on BayWatch for making a mistake.)
1130: WILD 1 to BayWatch on «270.8» reports 5 minutes left.
1130: REACH 910 trying to "reach" Andrews on «378.1» not getting a reply.
1133: REACH 910 makes contact, arriving 20 minutes has 11 pallets, pax and 1 rolling stock to download. «378.1»
1136: REACH 7429 reports airborne from Andrews at 1629Z «378.1»
1140: WILD 1 coming home...«270.8» with BayWatch and then to Potomac TRACON freq «270.275»
1144: TESTER 16 calling BayWatch on «354.8» "just to let you know we'll be climbing vertically."
1147: DC 51 and DC 52 tankers meet up...looks like they may be practicing refueling techniques together «351.2»
1152: Langley's «364.125» active.
1155: TROOPER 17 reports 8 miles to the east of Martin State Airport and coming in for landing on tower freq. «121.3»
NOTE: TROOPERs 1-8 are MD State Police helos primarily used for medevac purposes and are scattered at various airports around the state. 9/10 are fixed wing aircraft of the MD State Police. I've been told the 17 suffix is used for ferrying helos around the state. Also had a TROOPER 11 within the past couple of days and have no idea what that might be.
1201: JOSA 437 to SAM Command on «141.55» to report arriving Andrews at 1725Z, tail #40099, A-1, offloading 6 duty pax, will take 4 Space A pax on outbound and plans to depart at 1920Z. Parking in 3 Row.
1210: DC 52 reports level at (altitude) 250 and heading south «351.2» "We are about to do a descent down to 15."
1217: Chat on tanker interplane freq «143.825» suffix 50 and 51 heard.
1220: TESTER 16 on Pax River «256.5» reports runway in sight
1221: More chat on tanker interplane freq «143.825» This time it's 41 and 45. A minute later it's 50 and 51 again - or at least 51 calling 50 with no reply after several attempts and he IDs this as the interplane freq.
1225: Tankers 50 and 51 make contact and report altitudes as 270 and 280 «143.825» They are about to swap altitudes but decide they'll be at 275 and 280 to reverse whatever role they're performing. They have now switched to calling each other GOLD 1 and GOLD 2 if these are the same two.(Turns out it is the same two) The GOLD callsign is used for trans-Atlantic tanker flights, west to east. Coming the other way they use callsign BLUE.
1233: GOLD 1 reports at FL240 and GOLD 2 at FL245. «143.825»
1242: GOLD 1 and 2 still descending...going now to 11 and 12,000. "GOLD leader say airspeed." "310 knots."
1244: Now calling each other 50 and 51 again..."We're going to push it up to 330." "Cool," is the reply.
Guess they were too low and too distant because that's the last I heard from them - at least over the next 20 minutes that has gone by.
1304: DC 52 Heavy to Andrews Approach on «119.3» to do pattern work.
1312: PAT 143 to Navy Ops on «139.3» reports 7 minutes to blocks and 4 minutes to wheels down. (Notice they use both 139.3 and 139.4 for Navy Ops at Andrews)
1313: PAT 143 reports visual on the airport to Andrews Approach on «119.3»
1319: DC 52 still going 'round and 'round at Andrews with Approach «119.3»and Tower «118.4»
1325: NJ-ANG F-16s active on tac «138.425» Callsign DEVIL
1326: DC 52 on squadron freq «351.2» mentions DC 51 is over Dover right now.
1332: DC 52 mentions he's going to stay up another 45 minutes to an hour. «351.2»
1336: NJ-ANG flight of two F-16s in ground attack exercises...they sound like they're in this area considering signal strength...but have not heard them on any of the Center freqs nor on a Pax River freq...just on tac «138.425»
1339: Finally...it's the DEVIL 11 flight from Jersey with ZDC-Kenton DE on «277.4»
1340: DEVIL 11 flight going home. They report 10 minutes out and 1 is Code 1 and 2 is Code 2 to Ops on «261.0» and then switch to Victor freq for Ops on «138.125» where DEVIL 2 reports ground is weak but readable. Then back to tac «138.425» This was sure a short flight.
1343: DEVIL 11 flight to ZDC-Sea Isle on «285.4» and reports out of 11,000 for 9,000
1346: DEVIL 11 flight to Atlantic City Approach on «327.125» checking in at 8,000 and then to 7,000
1349: NJ-ANG tac freq «138.875» freq active. This may be the landing activity of the DEVIL 11 flight..very weak. Nope...hear them again on this freq at 1352 and it's a BANGER flight but still very weak.
1413: SLAM flight (Possibly F-16 VA-ANG Richmond but many other units use this callsign) with ZDC-Green Bay VA on «269.4» (Questionable ID on the callsign because I'm not hearing any of the VA-ANG tac freqs active)
1420: Either DC 51 or 52 mentions he's going to change plans and land in a couple of minutes. «351.2»
1423: Northrup Grumman guys report airborne on their «123.2» freq
NOTE: Chuck, you mentioned watching these guys take off the other day. They do use the main runways - not the short 15L/33R runway, correct? I'm in the approach pattern for that short runway but have never seen them overhead in either direction. Come to think of it, I haven't seen or heard that Piaggio P-180 recently either. He was a daily in/out visitor for months. When I didn't see him, I sure could hear those screaming engines.
1428: N-G guys to their main freq «123.225» Primary test aircraft is asking someone how this radio works - indicating the other had a problem. He then says he's ready to start the first test and "the speed will be one five...15 miles per hour." (That sure has me curious. What's he driving, a horse and buggy?)
1435: TROOPER 3 into Martin State on Tower freq «121.3»
1439: NJ-ANG tac freq «138.425» active and just heard someone on ZDC-Sea Isle «285.4» which I believe is the same flight. Callsign DEVIL 11
1440: Have a pair of fighters on Pax River's «256.5» freq. Id by one is 123 which probably makes him a SALTY DOG aircraft and no ID at all from the other.
1442: U/I aircraft - partial ID 539 and sounded like November Tango in front of the 539. No reply on GIANT KILLER's «350.0» freq so he switches to «255.0» and reports he's going into W-107 at altitude Bravo.
1446: DEVIL 11 flight at FL160 on ZDC-Snow Hill MD on «256.8»
1449: BOLAR 71 (C-5 Dover AFB) with Dover Command Post on «349.4»
1451: DEVIL 11 flight checking into BayWatch area on «354.8»
1454: DEVIL flight of two F-16s hard to hear...flight leader is weak and muffled. #2 aircraft just said he has trouble hearing him also. Setting up for their exercise on «138.425»
1459: NJ-ANG tac freq «138.875» also active. Callsign BANGER, flight of two.
1500: BANGER 21 flight into BayWatch area on «270.8»
1500: REACH 01 reports airborne at 1956Z to Andrews Command Post on «378.1»
1510: Both DEVIL and BANGER flights are in ground attack exercises on the Pax River Range in southern Maryland. Comms from DEVIL flight leader improved but the wingman is still asking for repeats of many transmissions because of the signal quality from the #1 man. DEVILs are low and BANGERs high altitudes. «138.425/138.875»
1538: BANGER flight headed home...now with ZDC-Snow Hill on «256.8» IDs as two F-16s RTB Atlantic City.
1538: DEVIL flight was just in front of them...now with Atlantic City Approach on «327.125»
1542: BANGERs with ZDC-Sea Isle «285.4» direct AC.... landing runway 31 reported on tac «138.875»
1545: BANGER 21 flight with Atlantic City approach on «327.125» report leaving 10 for 7, straight in approach to runway.
1547: TESTER 00 (zero-zero) with Pax River on «256.5» leaving 17,000 for 12,000
(TESTER 00 and a REACH 01 today - both callsigns I've never heard before.)
1549: TESTER 03 with Pax River on «256.5» reports vertical maneuvering.
1553: VENUS 32 reports full stop landing to Andrews Tower on «118.4»
TESTERs 00, 03, 08, 09, 15, 16, 18, 24 all heard today. Busy day for them.
1600: END OF REPORT
