Summit County 800 System
fpo701
OH DB Admin
Akron, OH
I don't believe we have enough information to submit. I can't believe that Penninsula has been the system for that long and we're just now discovering the Service Department talkgroup. Winters (especially last year) would have that talkgroup lit up with plow activity.
Let's sit on it and research more.
Well I didn't just now discover it. I've logged it in Jan, Feb, Aug, Oct, and Nov of this year. Not necessarily listening or able to determine who it was if I was.
fpo701
OH DB Admin
Akron, OH
That's why I'm not going to add it. I've had a few times where guys are on the wrong channel and call it that. I'd like to get some better evidence than one random name. IIRC, Penninsula PD referred to their talkaround as "Penn 2". He could have thought he was on another channel.
Hummer8290
Can someone please help out with programming of a pro651 for this system. I've tried programming the tables they way they were described earlier in forum with no luck . I have no software or desire to get any. Any help is greatly appreciated
Good luck with manual programming. :)
I can't help you with a 651/106, but the RRDB frequencies are up to date and you do have to program the rebanding tables. I'm sure someone will be along to help.
Swipesy
Northern Ohio
Do yourself a favor, download WIN500 or PSREdit or ARC500 and you can use them for free for 30 days. Programming these scanners manually is not the way to go. With the software you will be up and running in 1/2 hour versus days by hand.
Hummer8290
I don't have cable. Not interested. If someone has them,please let me know
So you have done this and it doesn't work?
Programming Shortcut PSR-500/600 RS Pro-106/197 - The RadioReference Wiki
Actually the only two frequencies without a "5" in the forth decimal place are 851.80000 and 853.65000. So The system will work without rebanding except any voice traffic on those two frequencies will be missed. Not a big chance. I ran the system without rebanding for a time until I realized it was rebanded. Didn't miss much.
Nasby
Ohio
Unit6817
There's a guy on Akron Craigslist that programs those scanners.
Hummer8290
Changed it to default, without custom,seems fine. A guy on Craigslist that programs scanners doesn't sound to good!
Well I made a point to notice tonite, and 851.80000 and 853.65000 sure came up a lot - so you do miss a lot without the reband table.
Hummer8290
OK. So back to square one. Does anyone have the pro651 reband table? The one mentioned earlier in the forum ,doesn't seem to work
fpo701
OH DB Admin
Akron, OH
The PRO-651 is the Whistler version of the GRE PRO-106.
Take a look at the wiki. The main rebanding article has references that the PRO-106 uses Object Oriented Scanner.
The Object Oriented Scanner Software - The RadioReference Wiki page has the rebanding info at in the Win500 section. The table is identical to the Uniden version I use, but matches the setup that is needed for GRE/Whistler.
I've never used GRE/Whistler radios, so I can't offer step-by-step instruction. There are a few PRO-106 folks around here. They can probably help if you get stuck.
Hummer8290
I did just that,and programmed by hand what's mentioned in the article, thanks
Nasby
Ohio
Just out of curiosity, how long did it take you to do the programming by hand?
jimmyo
Cuyahoga Falls, Oh
What i don't understand is why people spend so much on scanners but do not want to spend the 15-30 for a cable and software.
Hummer8290
Took me about 20 minutes to half hour fot everything. I enjoy doing everything by hand ,because I've had and toyed with scanners for 30 years. I consider it part of the hobby. If you don't understand,that's OK too.
Logged a number of hits on TG 43024 with RIDs 31268, 31269, and 31271 around 3 PM. Wasn't listening at this time. This has been tentatively IDed as Northfield Village FD I think.
