TCA PRC-152a forums, user groups?
TDR-94
The Thales PRC-6809 MBITR does all the splinter freqs I've ever entered just fine. Its also 30-512MHz continuous AM/FM/Narrow FM and LPC10 digital voice with DES or AES encryption. I believe the scan list can be at least 16 channels. I had eight of the MBITR series over the years and a couple of the Harris versions made by Thales before Harris designed the PRC-152 series. This was part of my brood at one time.
That 2nd one in, from the right, looks strangely familiar for some reason.....
TDR-94
The one I had would not do any of the VCALL/VTAC frequencies or DPL which rendered it pretty useless.
Yeah,the PRC-6809 doesn't support DPL/DCS encode/decode,which is kinda odd. Not sure why it wouldn't allow you to program VCALL/VTAC channels.
Interesting that you mention the front end being wide open on UHF-AM. Curious, did you have issues with it picking up certain frequencies because they were covered by noise, even with the squelch level set to it's highest level of 16dB?
gtaman
TACSAT
GALAXY 19 91.0° W
I had mostly the “swirling” audio effect on mine. UHF AM has always been noisy for me. There were a couple freqs that did not play well with my 148. But it could if just been my radio. I had no clue when it was last tuned and hell it had sand all in it 😁.
BigLebowski
Piedmont NC
Mine was completely unusable on most of the UHF AM I needed and I couldn't squelch it out.
No issues with the Harris which I think is just a better radio overall.
wb4sqi
Amelia, OH
Found it, title is: TRI/TCA radio Mbitr Owners B/s/t
Huh! a rudderless ship, no admins or moderator has responded to my membership request. Of course this is a Facebook forum so probably to be expected.
I'd like to initiate a forum in groups.io but getting notifications to the right places to attract members appears to be my stumbling block at the moment.
TDR-94
Yeah, I can't monitor certain UHF-AM or VHF-AM frequencies at all because those frequencies are covered in noise and they can't be squelched out,but others are just fine. My IC-R20 has no issue with noise on the same frequencies.
Is the Harris an RF-310M-HH by chance?
BTW, the Thales PRC-148/JEM/6809's that are maritime versions, have such bad speaker audio because they use a piezo electric driver instead of a water resistant speaker, that's used in the urban versions. There were a lot of complaints about the speaker audio when using the maritime versions.
prcguy
I know someone that had an MBITR as you describe and he took it all apart, tightened all circuit board screws and related hardware and it seemed to cure the RFI/birdie problem. But there is a published list of potential frequencies that may have internally generated interference. The Thales MBITR is the first multiband SDR radio ever designed to my knowledge and it converts all receive frequencies up to around 1700MHz before digitizing and processing. Its really complicated inside.
The very first commercially produced SDR hand held radio was the Thales MSHR in VHF, which is the little brother to the MBITR. Its also probably the rarest radio you can find for military radio collectors, nearly all were destroyed due to the internal Type 1 encryption. There are a small handfull of these in collector world with the Type 1 encryption removed.
To keep this on topic, some of the cheap Chinese handhelds are SDRs and possibly the radio modules used inside the TCA and TRI look alike radios. If so that and the outside physical appearance are the only things the look alikes have in common with a real Harris or Thales military hand helds. The is nothing cheap or Chinese in the real radios.
gtaman
TACSAT
GALAXY 19 91.0° W
Uhhh well you better buy this one
prcguy
I currently have two of them and one is mint in the box with what looks like all accys. And I have a couple of the convertacom type mobile adapters with 25w amplifier and a bunch of batteries to rebuild some day. These are FPP VHF radios and even though the Type 1 encryption has been removed they have DES and will keyload and will talk to older radios like Motorola Sabers and Thales T25s with DES.
wb4sqi
Amelia, OH
Update!
Finally got into the FB group and it is starting to be a good resource. Ordered parts to build my own programming cable. Next obstacle will be to get the software to run on Win10.
Amazed at the battery life on the PRC-152. Set up 6 memory channels to scan, ran all day yesterday and dropped .1 volts according to the startup voltage display.
prcguy
Some of the look alike versions will take the the real batteries and there are 6.8AH batteries available for the MBITR series. I've bought some 5.8 and a 6.8AH for good prices on Ebay. That should power a look alike radio until the sun burns out.
Update!
wb4sqi
Amelia, OH
The knockoff battery uses four 18650 batteries in series/parallel for 8.4 volts at full charge. The "real" Harris battery is a higher voltage?
gtaman
TACSAT
GALAXY 19 91.0° W
Who had them? A factory guy mentioned very few PRC-6809 variants were ever sold in the US with most going out of the country. The real MBITR series including the 6809 is extremely durable with an excellent track record.
Mae got them in to destroy from some coast guard unit. I want to say they used them out in the pacific.
I let my brain wander. They were 148s. Non JEM variants. They were left in vehicles all day and essentially baked and burned. They were on a destruction pallet.
prcguy
I happen to work with the USCG and I've never known them to use the MBITR series, they have and use the Harris XG-100P.
wb4sqi
Amelia, OH
The real batteries are in the 12V range. I've seen some advertising where the knockoffs will use the real battery.
TRI version advertises they accept the 12v Harris batteries but I have not seen anything from TCA to confirm the higher voltage. TRI will have a 10 watt output with the 12v batteries but IMHO going from 5 to 10 watts isn't a big jump. You just generate more internal heat.
