thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,896
- Reaction score
- 897
Hello,
here is a bug. I can't say if it's generated by the network itself, the tetrademodulator plugin, or TTT.
Sometimes, the txer's SSI is not displayed in the calls window of TTT.
I don't know if it's not forwarded to by the tetrademodulator plugin, or if a wrong SSI structure generates a kind of parsing error, or...?
It results of this missing that the "SSI" is replaced by a "-1" in the "TETRA_SSI.txt" file, like this (third line) :
TTT continues to work without a problem, until you decide to close it and start it again.
It then aborts, generating a type mismatch error :
Deleting the file or only the line containing the "-1" solves the problem.
Hope it helps !
Gwargl
This was a problem back in v1.0.16.0
You will need to look in the status panel (above 'Call Details' panel) to see if a message about the bad ISSI/GSSI is there with timestamp.v1.0.16.0
CHANGED: G/SSI of '-1' was sometimes saved in records which caused a "Error in: SortGssi" or "Error in: SortIssi" on start
- Added a message in status panel to indicated bad G/SSI and time seen.
- The '-1' is seen when retrieving G/SSI value from a PDU and it was not seen (but is expected).
Cause PDU unknown at this stage.
- This does not fix this issue as we need to determine what PDU is causing it to happen.
If it is, you will then need to look in the logs 'TETRA_cc_xxxx.log' or 'TETRA_vc_xxxx.log' for the entry then send it to me unmodified so I can see whats going on with it. Check to see if you have more than one.
You will need to do this before TTT is shutdown or that timestamp info will be lost.
Latest version (v1.6.3.4) can be found here: Release post
- Please download 'TTT_1.6.3.4_release.7z' and install.
- Also download 'TTT_hotfix_v1.6.3.8.7z' and copy and replace the two files into the above install.
