Notice 5 positions the first 224;223![]()
Ahh yes, I forgot to put in LA
Country Code : Network : LA : Frequency : Label.
Windows 10 / 64
When using TTT i see both Network info screens in below windows taskbar, using ALT TAB i cant get Network info come visible on desktop
if anyone else have this, please report this matter to thewraith2008
That shows a private call, not a group call.Hi, I have a question how to change this option in the picture so that it is written there, e.g. Group assigned to issi, as it was in previous versions? I try and can't change it even in G / SSI Monitor
You can not change the 'Group' label for private calls.
TTT has been this way for a long time.
All private call ISSI activity is stored under GSSI: 0
The 'Group' label for private calls should one of the following:
- Private - Simplex
 - Private - Simplex[half]
 - Private - Duplex
 - Private - Duplex[half]
Latest version (v1.6.3.2) can be found here: Release post
- Please download 'TTT_1.6.3.2_release.7z' and install.
- Also download 'TTT_hotfix_v1.6.3.3.7z' and copy and replace the two files into the above install.
Question is
Why or how the tetra_trunk_tracker.dat file get corrupted.
I am very sorry , do my hurry to solve this matter, i deleted the corrupted file.... next time when it happen again i save the file.... but i hope or wish its solved by itselfIf you had sent me the file as I requested, maybe I could have looked into it.
If the position coordinates are some how wrong for 'Position SDR#' then shutdown TTT then backup 'tetra_trunk_tracker.dat'. Delete main 'tetra_trunk_tracker.dat' and restart TTT.
If that fixes problem then send me the backup 'tetra_trunk_tracker.dat' so I can see what is problem.
That's not how things get fixed.but i hope or wish its solved by itself
Not sure if i understand tomekjkp correctly in version 1.0.14 tomekjkp whas able to change or set a name label in private simplex calls ?
In this new version tomekjkp is not able to set a name label in private simplex calls ?
thewraith2008 did you change the name label function for private simplex calls ?
Before read your instructions, deleted the whole corrupted version and did new install and that helped to solve this matterWhy do I bother offering help to solve problem if one is just going to skip over the instructions I give.
FIXED: LLC protocol PDU reconstruction error
- Key with same name.
Includes hotfix update (v1.6.3.3)
Updated documentation
see 'changelog.txt' for full list and details.
	Summary of changes:
No changes but includes hotfix update (v1.6.3.3)
Rolled up version for release.
	translate:Questa nuova versione 1.6.3.4 in MODALITÀ SINGOLA
impostare VOICE AUTO su questo non funziona
TTT requires the 'Auto' is disabled.This new version 1.6.3.4 in SINGLE MODE
set VOICE AUTO this is not working. When listening to NONE trunk channels i missing lots simplex calls.
When switch to other or close the TAB sndcp, the sndcp function is turned OFF
NETWORK
private call over 2 different MAIN so one voice is on MAIN-1 and second voice is on MAIN-2
