UBCD3600xlt
rocky28965
Otago, NZ
Does anyone know if a UBCD536PT program will run on a UBCD3600xlt.
Assuming it's been created on UBCDx36 Sentinel.
Ubbe
Stockholm, Sweden
I would think that any Uniden SD card scanner can use another SD card scanners programming if you export and then import the programming, regardless of model type. As the files on the actual SD card can be configured differently it in some cases doesn't work to just move one SD card to another scanner if they are of different region models.
You can install both PT Sentinel and 3600 Sentinel and then do the export and import and see if it can do it without giving an error. If a program works in 3600 Sentinel then it will also work in the UBCD3600 scanner.
/Ubbe
rocky28965
Otago, NZ
That sounds like something I could manage.
Although I just found out the UBCD3600xlt will use Proscan, so I can import from there as well.
Most of my programs have been created on Proscan.
Xplorer00
No. UBCD3600XLT uses a different Sentinel version than all other Sentinel versions.
SD Cards are not interchangeable between the Uniden scanners.
BUT, if you're talking about Favourites List, then Yes.
The Favourites List for all Uniden scanners listed below are interchangeable by Exporting one and Importing to another.
Unfortunately, you can only export/import one Favourites List at a time (no bulk export/import using Sentinel).
If you export a NXDN/DMR/ProVoice/dPMR Frequency List, then import it into a scanner that doesn't have that upgrade, the import will not work correctly.
(SDS100, SDS100E, USDS100, UBCD436PT, BCD436HP, UBCD3600XLT, BCD536HP, UBCD536PT, SDS200, SDS200E).
Ubbe
Stockholm, Sweden
Do you know exactly what happens if conventional dPMR frequencies are imported into US Sentinel and then into a US scanner model? And what happens to trunked DMR systems when trying to write to a scanner that doesn't have that upgrade?
/Ubbe
rocky28965
Otago, NZ
All done now, wrote a SDS100 program straight to it with proscan.
Didn't have to change a thing.
