I believe the "key" way of doing it went away years ago. Follow the below link to download the updater and FW...Just wanted to bring the software up to date. Other user never did updates. I now have it to 1.04.12 but can't get past there with ought the activation key.
Opened a support case with Uniden. See if they reply. I know I can use it w/o all the updates, but figured I would just get it up to snuff before I put it in service.In the firmware update link you posted it says: Run the BC_VUP application you installed in Step 4. Follow all on-screen instructions. If you are updating from version prior to V3.00.00 you must enter the V3 Registration Key when prompted.
The OP is updating from 1.04.12 and therefore needs a registration key to update the firmware to version 3. This key is a 24 character string consisting of numbers and is generated from the the scanner's ESN and checksum. Only Uniden can provide this code.
Funny I never thought of just trying it.... 🫤 I shall report back.Maybe, the keys are no longer required. Try doing it without the keys. You will need the BC_VUP 2.0.0.7 firmware updater. I tried to attach it for you, but it is too large. I have the 3,02.00 SCN firmware file. Please let me know if you need it.
The updater asks for the key I believe. Or it did when I tried it a couple of days ago.Funny I never thought of just trying it.... 🫤 I shall report back.
Yup!!! and no word from Uniden yet.The updater asks for the key I believe. Or it did when I tried it a couple of days ago.
