I have never seen a 15 Ohm speaker in a Uniden base/mobile scanner. Not in Radio Shack either. They have all been 8 Ohms, rated between one and three watts. The TDA1905 is not too powerful for the internal speaker. With a 14 volt supply it has only a two watt output capability into 8 Ohms. Reproducing voice audio has low average power and there are many examples of the TDA1905 directly driving an 8 Ohm speaker rated at one or two watts. See for example the PRO-2004 and PRO-2006. Also see the Uniden-made examples in the pic below.
I have owned the PRO-2004, PRO-2006, BCT15X and others that directly drive the internal speaker from a TDA1905. There has never been an excessive thump on turn on or turn off. Nothing even close to causing speaker damage ever.
Aside from the BC780XLT I have not seen the addition of an 18 Ohm resistor in series with the internal speaker in a scanner. There is no need for it and it only reduces performance. Maybe the BC785D and BC796D have the same resistor since they are of similar vintage to the BC780XLT. I had a BC796D years ago but no longer own it.
