Uniden SDS100 FCC Approval Time-line
W5RGP
Charlotte Tn
While this may have already been answered downstream what we said is that the special cable (Previously introduced for the 325) will power the radio and the GPS from a single USB power source. The cable has 3 ends, an S connector for the GPS puck, a USB Mini to pug into the radio and a USB-A to plug into a power source such as the USB port on the vehicle. It could also be used with one of those battery packs marketed for phones that provide a USB power jack.!../QUOTE]
I may want one of those. Do you have a URL where I can get one?
Is there such a cable for the 436?
I’d like to eliminate my cigarette adapter plug
eorange
♦RF Enabled Member♦
Cleveland, OH
And there are places in Myrtle Beach where your scanner would perform as it does in Ohio and places in Ohio where it would work perfectly.
The underlying technology used in the SDS-100 ensures it will perform the same in similar environments tens, hundreds, or thousands of miles away.
It only matters where I am, and where I am and was is the only thing that matters. What good does it do me if there's no LSM distortion with my 396 in Toledo?
ur20v
The Feds say my name hot like when the oven on
NOVA
If there's no distortion, why are you asking?
Where I live, Loudoun county, Virginia, many people complain about LSM distortion, but I've never experienced it with my 436 or 536. I'm not in the market for the SDS-100, but I'd be interested in a Home Patrol 3 for something more car-friendly in the future.
N9JIG
Sheriff
Moderator
Far NW Valley
No, I tried to use the same cable for my 436 with no joy.
I don't know if there will be a way to do so with a firmware update down the road, if it requires hardware changes then I don't see that happening unless a third party wants to make the mods.
N9JIG
Sheriff
Moderator
Far NW Valley
By the video most of the testing are done in Ohio .You need to do other states .There are big problems in other states .Like N.C.
That is just where the most prolific video guys were. The SDS100 was extensively tested in many states, I know I did so in at least 7 different states. Others did a lot of testing in many other states but just didn't post videos.
jasonhouk
Marion, Ohio
It just seems that way as I post the videos of my testing here in Ohio. Other Beta Testers from all over are just not posting their videos due to anonymity or other personal reasons.
Houk
RF23
As we learn more about the SDS-100 it is looking better all the time and looking at some places it will be able to be purchased from I noticed that at HAM RADIO OUTLET’s SDS-100 RESERVATION they have the following:
“Due to the shipping complexity of this item an additional shipping charge will be added when shipped.”
What is complex about shipping a handheld scanner?
And above a picture of the SDS100 that have:
“Fright Item in RED with an Exclamation mark inside a triangle.”
I thought fright items were too big and/or too heavy for UPS or FedX.
Anyone have any info on this?
https://www.hamradio.com/detail.cfm?pid=H0-016147
milcom_chaser
Where we are the LSM is so bad, it sounds like Neo shortly after he swallowed the red pill in the movie, "The Matrix"...
Hit_Factor
Saint Joseph, MI
I think the ad used a template with all that freight mumbo jumbo already listed. I'm hoping its just an error.
Soundman
N.C
Charlotte distortion is the big problem here .If I am going to buy that new radio I would like to know it is going to work before I buy it .
RF23
I know people who have moved to a different part of the same city & found the LSM to be very different between the two places. So, you may need to borrow an SDS100 to be sure where you live it will work acceptable to you.
However, the SDS100 may not be as sensitive to such things as the present scanners are, but still I think you would want to know this before laying down $700 to $800.
radio3353
It is illogical to think the beta testers can try every simulcast system in the US. My advice to you is buy it, try it and if it does not work, return it. Seems like a reasonable plan, no?
hiegtx
Mentor
Dallas, TX
Either that, or wait until there's a few 'early adopters' in your area, and see what they are reporting. I would suspect that if there are specific problems that can be addressed via firmware, Uniden will likely do that. Much as we are seeing regular updates for the x36HP series after the NXDN release, some of which also include improvements on DMR or P25 functionality.
As you note, it's impossible for a small qty of beta testers to test every single system in the country. They give as much feedback as possible, but once the scanner hits the market, I would not be surprised to read about a few 'problem systems' that require more tweaking.
That is the only way to know for sure. Even if someone buys one in your town you still have to test at your site to know how well something will work.
Exactly. There are several 'problem systems' in my area that have issues on the scanners currently available. But, at my specific location, I don't have an issue with them at present. I'm far enough outside their simulcast coverage that I don't have a problem. Others, in different locations, may not be as lucky.
jonwienke
More Info Coming Soon!
VA
The biggest thing to remember is that the SDS100 is specifically designed to handle simulcast, unlike every other previous model. And it's being tested in some of the most challenging simulcast environments in the country. And every indication so far is that it's handling the challenges just fine. Being specifically designed to handle simulcast makes a big difference.
mule1075
Washington Pennsylvania
Honestly no S%*&.I could very well be wrong but I am guessing that their were a few beta testers around other systems that did not get posted here or any other social media. I do apologize for my candor.
