V1.30 G2-G5 Firmware Released
CanesFan95
Was Homeboys-Scanna
Banned
FL
Is there also a scan delay, or just a hold feature?
gcopter1
Winter Park, Florida
Are there any plans to include in a future FW update of v.1.3, the ability to map the play key as the TG hold button?
I wear my G4 on my waist belt and, trying to find the TG hold button in its current spot is difficult without actually pulling the pager off and looking at it.
blackbelter
Not to mention that the current Unication friendly Carrying cases designs don’t accommodate For these features . One has to remove the pager from the cases to activate these buttons .
shawnr0007
Douglasville Ga
There are no issues with the site links. I have checked with multiple browsers. Anyone with V1.1 or V1.2 can download the latest V1.3 release. If you are part of the beta group for the scanning V1.4 software don not flash backwards to V1.3.
I upgraded now pager wont work is there a way to flash back to 1.2version
bob550
Albany County, NY
Can you better define what you mean by "won't work"? What is the pager not doing correctly? Did you carefully follow the instructions including downloading the 3.16 PPS?
shawnr0007
Douglasville Ga
I
I upgraded pps and firmware from unication website when I lose my code plug nothing all I see is my site my zone and all it keeps doing is scanning no traffic it was working before I upgraded to the firmware
RBMTS
Before you updated the firmware did you read and save the code plug with the new PPS? And then after you updated the firmware, did you try reprogramming in the code plug you saved with the new PPS?
shawnr0007
Douglasville Ga
I did backup my original code blue but it also doesn't work after I did the upgrade so I tried make a brand new one and that doesn't work either.
blackbelter
As previously mentioned , your dealer may be able to provide you with a roll back option and a 1.2 link .
MidwestRadioListener
Altoona Iowa
Hi Guys - I updated firmware and PPS after the new was posted. Everything has been working great since then except one thing. I've so far not seen anyone ask the same thing and not been finding anything in google searches outside this site either. When I receive traffic on the system I listen too most often the Talkgroup ID and User ID/Radio ID are hex vs decimal now. I had thought there would be a setting on the device that maybe was new and not able to locate anything. I also haven't found anything in the PPS. I've been dragging my feet posting but can't deal with it anymore. Anyone else have this happen or know what might need changed on my end? Thanks a bunch.
bob550
Albany County, NY
Try programming a completely new profile with only a single site from a single system into the pager. If that works, you may have an incompatibility in your existing codeplug with V1.3.
RBMTS
Look at the very bottom of the D8 page. There you will see "Display Format Setting". I believe that is what you are looking for - if I understand your question correctly.
RBMTS
See if you can reload 1.30 firmware. I don't know if it performs a version verification and will stop the update or if you can reload it a second time. Maybe a second update will fix the problem just in case there was a data glitch with the first update. Worth a try.
Altoona Iowa
Thanks RB !! That was exactly what I was looking for and apparently didn't quite go far enough down into the settings.
