Right now I am following my local sub-system in the All/Wildcard (65535) mode. I have the Receiving Mode: Trunking TG-Monitor with a All/Wildcard (65535) in the Priority Talk Group List. Is that the correct way to program it? I seems like a couple of firmware version ago there was a different way to go into the Wildcard Mode from the radio itself, but I assume that it no longer available.
I think the 'Trunking TG-Monitor' is the new equivalent way to monitor the system as a Wildcard. It works for me that way. So also having the TG 65535 is redundant. I also did find out that you can only program up to 63 TGs when using that mode. Apparently It'll let you enter 64 TGs but once you program the pager and start using it, it'll give you a "programming error" like it needs an empty slot for the TG-Monitor mode.
When I see the flashing green screen with white lettering TGIG Removed, I assume that simply a reminder that a talkgroup is locked out. I may have to see if I can eliminate that, but no big deal if I can't.
According to 'Uni1', there's no way to get rid of that at this time.
Yes, I've seen up to 64 TGs somewhere. Maybe on the software release notes.Has anybody here tried to see how many talkgroups can be "Blok"d while in the All/Wildcard Mode? I seem to recall seeing 64, but we shall see.
