We Need Freshly Updated and New Database Information for Michigan (Non MPSCS)
garryd451
Pokagon, Michigan, half way between Niles and Dowa
Database
Berrien County
Niles City Police Department
On the Data Base, 453-9750, 453-9500 and 460-5250 are listed for Niles City Police. I have heard nothing on these for many, many months!
I was told by a Niles City Police, who I asked, that they are on a private radio system, that can only be monitored by their radios.
marcp90
Central FL
Try the MPSCS for Niles. The DB has it listed as 13026. The best tower for Niles would be the Sumnerville tower
krokus
Southeastern Michigan
Which may be true, but I am more inclined to think they do not know, or do not want to share the information.
Sent via Tapatalk
firephotographer50
Port Huron, MI
I've noticed that unless you are friends with the officer in question, they will not give you an answer to a question like this. It makes sense and I don't blame them. They don't know who you are or why you want this information and it is a personal safety issue for them.
If you have any radio related questions, the fastest and most accurate responses come from posts on this website. I haven't been led astray yet.
Now back to the main topic .....
kd8eee
Cass county road commission is now operating a TRBO system as opposed to analog. Same frequencies.
canusa2
yes in macomb county i cannot pick up any police or sherrif im using uniden bcd396xt scanner does anyone have a guess as to when these frq will be available on rr
detroit780
Silent Key
Michigan
Macomb
Have you looked here?
Michigan's Public Safety Communications System (MPSCS) Trunking System, Statewide, Multi-State - Scanner Frequencies
2 (2) 019 (13) Macomb County Simulcast Macomb 851.06250 851.13750 851.18750 851.37500 851.42500 851.43750 851.65000 851.76250 851.90000 851.98750 852.38750 852.48750 852.65000 852.67500 852.73750 852.98750 853.26250a 853.98750c
canusa2
i seen that but im not that savy with the freescan software to program the indivigual frequencies so i need to wait until it comes up on radio ref in the program where it does not say depriciated thanks though
detroit780
Silent Key
Michigan
Macomb
Well if you use RR to program the scanner it should pull in the new data. It's in there now and all the previous frequencies have been removed. So there is no way to program the incorrect frequencies via a RR download through the software.
i seen that but im not that savy with the freescan software to program the indivigual frequencies so i need to wait until it comes up on radio ref in the program where it does not say depreciated thanks though
canusa2
well i just looked an saint clair shores , sherrif, roseville etc are still saying depreciated i also called able electronics they said it may take rr weeks to update the database of all the ones that switched to MPSCS ALSO i looked at windsor an it said windsor police is unmonitorable it sure seems strange that all of these comunities would go down together this fast jason at able electronics said he has never seen anything like this an he has been referring people to tri- county communications to have there scanners reprogrammed so i called an the lady said it will probably be a couple of weeks before there excepting scanners
canusa2
i did try to use the present freq on their that say depreciated an i get nothing
kd8ati
Southeast MI
Listen to what the people here are trying to explain to you. The ONLY reason you would be getting depreciated is because you are trying to look-up their old analog freqs or their old talkgroups. Both St. Clair Shores & Roseville have joined SERESA. Look in the database under MPSCS > Macomb County > SERESA. Eastpointe is also part of this consolidated dispatch center. Macomb County sheriff remains on 50MASH as it always has. In order to receive all these talkgroups you simply need to program the new 85x.xxx listed under the Macomb County Simulcast of the MPSCS.
The reason you cant monitor Windsor PD is because they have been encrypted for the past several years. You can not legally monitor any encrypted communications.
Jason has never seen anything like this because the entire state just re-banded all their MPSCS towers, and he is likely flooded with people saying their scanner isnt working. All that is required is to reprogram the scanner with the new frequencies and it WILL work. I am listening to Macomb County / SERESA right now with no issues.
Ronaldski
MI DB Admin
Bay City MI
Although all valid questions and answers starting with comment 106, but this forum thread has to do with as the first message says -
We are seeking new and/or updated information for the Michigan database.
What we are asking is that you look at the current Michigan database for your area (and others if you wish), and verify what is there. Also, if you notice anything that is missing please let us know that as well. Newly found frequencies, TGIDs (with the exception of the MPSCS), and systems may be posted in this thread as well.
Should really start a new forum thread imo.
canusa2
thanks for putting up with the novice I''ll try to figure it out now with the good info you have provided hope i wasnt to much of a bother im trying to learn
kd8eee
St. Joseph County road commission is now DMR. Same frequencies.
Ronaldski
MI DB Admin
Bay City MI
For http://www.radioreference.com/apps/db/?aid=2724
While in MIO I picked up a good 5 bar signal on 169.9250 but with a pl 123.0 Then just after heading southbound briefly saw same freq but with the listed 186.2 but was very weak. 123.0 PL is popular on that database link, but 186.2 is listed just this once.
Currently it shows,
Manistee National Forest
169.92500 186.2 PL Rangers
wmm1200
I also received the US Forest Service on 169.925 with a PL of 127.3 from Iargo springs in Oscoda.
It was a fire weather broadcast Sunday, 7/13 @ 1100.
wmm1200
^^^ Was in Mio yesterday, they referred to the above channel as "admin-east" with the PL of 127.3.
Gpmorris62
Remus,MI.
Big Rapids City Police & Ferris State Campus Police are now on 155.190, 131DPL.
155.550, 162.2PL are Mecosta Co. Sheriff & MSP only now.
