XTS3000 What is needed to program a Motorola XTS 3K?
I am a lineman for the county.
What are the consequences of not using a service monitor or tuner? Thanks for all the help from everyone
Electronic components age and their values drift. When the radio is built, it gets aligned so it works properly:
-Actually transmits on the correct frequency
-Actually receives on the correct frequency
-Puts out the correct power
-Receiver sensitivity is well adjusted so it can hear weak signals
-Transmit deviation is correct so it's not transmitting outside it's assigned channel.
-CTCSS deviation is correct
-bunch of other stuff
When the radio ages, the components drift and the performance of the radio often goes out the window.
For any sort of public safety use, that's got a number of issues:
-Radio will not work correctly, and if your life depends on the radio, that's a stupid place to put yourself.
-Radio could end up causing interference to other users - that puts their communications at risk.
-FCC requires the licensee (your agency) to make sure the radio does not cause such interference, that means they are responsible for fixing it, or replacing your radio.
If this is for GMRS use, there are requirements that your radio work properly and not cause issues to other users.
If this is for amateur radio use, do whatever the hell you want, it's just a hobby, but a crappy sounding radio (off frequency) will probably get some complaints.
Chances are the radio may be "good enough". But for the average hobbyist, that can be difficult to determine without the right test gear.
On the other hand, getting an old radio like that properly aligned, will make it sound good, perform well, and give you a few more years of useful life out of it. Kind of like giving your car a tune up.
Cashanova48
GMRS callsign WSAF780
You really don't know until you have the radio FCC'd. It may be within tolerance and just a slight tweak on the alignment or a whole lot of adjustment. The Motorola XTS3000 is nothing more than a disguised Astro Saber but a very stout radio.
I have several Astro Sabers and XTS3000 and I still use them occasionally but, I mostly use my XTS5000 Type III a majority of the time.
Where could I get a radio "FCC'd"?
nokones
Sun City West, AZ
I would try your local Motorola Dealer that services and repairs radios. The problem you may run into is that they may not service that particular model because of the age. You might want to try an independent radio shop.
Action Wireless in Tucson, AZ will work on some of the vintage radios. They are an authorized Motorola Sales and Service Dealer. You should call them and check and if they do you can send the radio to them.
Cashanova48
MTS2000des
5B2_BEE00 Czar
Most shops aren't going to touch an ancient relic and may not even have the service tools to do it. The Astro 25 line is about as far back as most MSI shops will go. But won't hurt to ask. If they still have auto tune for those on their service monitors, a half hour labor is what the going rate is but they may charge more due to having to drag out unused tools like RIB boxes and find that old XTS/MTS test cable if it hasn't dry rotted to hook up to their RLN-4460.
Cashanova48
If you walk into a dealer and ask to have your radio "FCC'd", they're going to look at you like you've got a third eye. There's no such thing.
Tell them you would like your radio tuned and aligned.
Thanks for the help guys, I'll look around my area.
Much appreciated,
-Cashanova
nokones
Sun City West, AZ
It's a term that has been used for many decades for having the radio aligned and tuned to FCC specs. Kinda goes back to the old crystal days something that had to be done annually.
And no doubt most younger people wouldn't have a clue what that means.
GTR8000
NY/NJ Database Guy
BEE00
Well I'm "younger people" at only a half-century old, and I've never heard the term either...not once. Must be a silly local term. Gee, what do folks in Canada call a radio alignment and tuning? IC'd it? I suppose the younger folks would say they ISED it! 🙃
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
I'll pile on at 48 having never heard that either, likewise nobody outside the USA has ever heard or used the term. This forum has quite the international audience and we should stick to industry standard terms for ease of understanding (and in some cases translation!).
I have heard it referred to as PM'ing (preventive maintenance) also but that could encompass more than just verifying tuning and alignment such as physical inspection and cleaning or perhaps replacement of some parts per agency policy. Typically done at a specific interval.
And since we're piling on, it's 'model 2 and model 3' when referring to keypad/display not 'type' as that more commonly refers to trunking. If I said I had a Type 2 (II) radio that would mean Smartnet trunking not a limited keypad with display radio.
redbeard
BEE00.348-3.1
I forgot to add that the biggest issue with the XTS 3000 these days is that the flash memory is reaching it's end of life from being written over and over while the radio operates. Typically manifests as FAIL 01/82 on power up. Sometimes re-writing the codeplug fixes it for awhile.
Cashanova48
So far I've only received an error code due to the radio previously being set up for encryption (ex fedral unit), and with the board being wiped it won't communicate with the radio. I should just have to switch it back to in the clear transmissions on the cps.
I'll keep an eye out for any more errors, like the one you mentioned. I was completely unaware that the flash could go bad overtime.
Thanks,
-Cashanova
Cashanova48
If I use this radio to listen to (and after being licensed talk on) a local armature radio repeater that is P25 and to my knowledge open to the public, do they have the right or the opportunity to kill or stun my radio? Or is that only a thing on P25 trucked?
