WPLN4219 Question
daugherh
Upstate SC
Hi all. I have a WPLN4219 6 bay Impress gang charger. I currently have 4 XPR series radios that I charge in it regularly. I also have a CP200D and a couple HT1250s. I found the Impress battery for the HT1250 (HNN4003BR) and was wondering if it would charge successfully in the WPLN4219 gang charger rather than having two single chargers on the shelf beside the gang unit with 2 unused slots. The back of the HT battery looks identical to the XPRs.
In some places I see this about the WPLN4219: "The user can use this charger to charge up to six IMPRES or non-IMPRES batteries to allow the radios to be operatable when working. The WPLN4219A can be used to recondition and optimize any IMPRES battery. This allows the batteries to perform their best whenever they are used."
That says ANY Impres battery. Other places I've seen says it only works with XPR series.
Can anyone confirm or deny if my HT will charge with my XPRs in the gang unit? Thanks for your help and expertise!!
K2NEC
5F6
No it will NOT work. The Waris batteries are wider than the XPR batteries.
I was worried I would have the same problem so I bought a WPLN4121BR and the XPR and Waris adapter cups. Please also know that the XPR adapter cups only work on Generation 2 radios they will not work with the Gen 1 XPR radios but it doesn't look like you have any of those anyway.
daugherh
Upstate SC
Thank you @K2NEC. Looks like I'll not be buying the impres batteries for the HTs then. Wish I would've thought about that before getting the 4219 charger and I would've done like you did.
daugherh
Upstate SC
@K2NEC , actually considering scooping up a WPLN4121BR. Any chances you can provide the p/n for the XPR and Waris cups? I googled them but couldn't find the items in question. That would help out a lot.
K2NEC
5F6
No worries. What are you going to do with the WPLN4219?
daugherh
Upstate SC
@K2NEC I'll probably either sell it or find someone willing to trade a wpln4121br (doubtful I'll get that lucky). Trading would be great since I'll have to buy the adapters for the 4121.
