XPR-6550 vs. XPR-7550
Anderegg
Enter text in this field
San Diego
You can get several 1 watt RSMs for the APX that will fit the XPR, just won't get displays or channel functions, but it would be double the volume of an XPR RSM. Since getting my 7350, I just hand it on the shoulder mic slit on my tactical polo like a large RSM, London Metro style :)
Paul
NotATechGuy
NotAMember
Motorola has 1w RSM's made specifically for the 6000/7000 family now. NNTN8382 and NNTN8383.
I use the 8382 at work on my 7550 and love it. Sure it's not an APX RSM but it sounds great.
Fire125
FF/EMT/HMRT
SE Michigan
Paul
Thank you for replay
KG4INW
Midlothian, VA
All UHF 7550s cover 403-512 MHz. Unless if a 6550 codeplug is what they're after, but I think it's the former.
Fire125
FF/EMT/HMRT
SE Michigan
xpr 7550 help
hi guys,
i just got my xpr 7550 and programmed it. so far i have two problems.
1-the first one is i can't enable voice announcement option (in the cps, when i click on manage voice announcement, it gives me 1921 error and tells me that it can'r find the applicable driver for it)
2-i programmed the first side button (the one on the top of the ptt) for monitor, but when i press it, it won't work. can someone help me with these?
same as always thanks for helping
Anderegg
San Diego
The CPS gives an error when you click, or when you try to program the radio?
What version of CPS are you using, and have you tried to uninstall and reinstall it.....maybe a driver or dll got missed on the prior install.
Are you trying to use monitor on an analog or digital channel? I think it only works on analog.
Paul
Fire125
FF/EMT/HMRT
SE Michigan
Paul
for using the voice announcement, i should go to the device and click on the manage voice announcement. when i do it, it gives me the error i said.
cps version 11.0 (built 596)
monitor on analog channel.
Anderegg
San Diego
Don't you have to LOAD your radio full of the voice announcement files FIRST, then do all the other CPS stuff? I got my voice stuff to work on my 7350's, but it's been a few months so I don't recall the exact process, but I remember having to load the radios up first before the files would show up on the voice file drop down lists.
Paul
Fire125
FF/EMT/HMRT
SE Michigan
Paul
that's exactly what i'm trying to do, for uploading the voices, i should open the manage voice announcement, which when i tried to do, i faced with that error
thanks for replaying
Amir
radioguy99
Phoenix, AZ
Does anyone have closeup pictures of the actual connector? I have searched high and low and can;t find one. I just asked our sales rep for our mobile radios here at work to see if he can get me a demo unit to play with :)
Here you go. Trying to get any help anymore is a struggle like going to the dentist and having a molar tooth yanked out. This is the actual OEM Moto test adaptor and the 7550 radio antenna jack close up. Hope this helps you out. Sorry for not responding sooner as I was also having issues locating any info on this a year ago and saw this post today years later. This is my radio and I decided to take it apart to help those who need to know what it looks like exactly.
N4KVE
PALM BEACH, FLORIDA
They look at it this way. A 2-way shop buys that for the going rate. It is to be used only for alignment on the bench. NOT for connecting a mobile antenna to the radio to extend range. At $50, or $75 per radio alignment, that device will help to generate thousands of $ for the shop. Sounds like bargain now, right?
N4GIX
Hot Springs, AR
For a service shop it is a no-brainer. I've read that it consists of two pieces, but I only see one piece?
Obviously the long shaft is to allow the adapter to pass through the access hole in the case.
tekheavy
Long Island, New York
The other piece is just to hold the adapter in place. At $150.00 extra, I do without it.
