HAPPY SCANNING!
The update will be available via the PC app after 6pm Eastern Time today.
The update will be available on www.whistlergroup.com after 8pm Eastern time tonight.
Instructions:
Update the PC APP
Update the CPU
Update the DSP
PC APP Release notes
* Redesigned the advanced options tab to include sub-tabs to allow the addition of new options.
* Added edit options for the RSSI received signal bars to the advanced options tab under the Display Options sub-tab.
* Added Load Defaults button on the DSP settings on the Receive/PCIF Options sub-tab.
* Added Options to allow modification to the ZeroMatic values for the scanner, including a Load Defaults button on the Receive/PCIF Options sub-tab.
* Added Australian band plan.
* When copying between the computer and the SD card, the default Delete flag will now be set to No.
* Corrected an issue when creating a new conventional channel using a CTCSS or DCS squelch value, the stored value would be saved incorrectly.
* Changed the Zeromatic code to verify and correct all values if they are found to be outside of allowed ranges
* Fixed a bug when attempting to load a list of trunked systems for import. This only occurred in some areas and under extreme circumstances.
* Corrected an issue where the trunking tables on Motorola VHF and UHF systems were not being set correctly when imported using the preferred method.
* Added option to the file menu to import the configuration from a WS-1040/WS-1065 or compatible scanner. This function will only download from the source scanner's working memory. It will not download from a V-Scanner folder directly.
* Updated the Save Configuration to Archive option to honor the -d command line switch.
CPU Release notes
* Added "Freq" item to Tune settings menu
* Filtered out Fn+<digit> combinations from scan list toggling
* NXDN: PROP_FORM message handling in conventional
* Added handling for certain multi-block PDUs (for some VHF systems)
* Fixed problem entering Skywarn mode when no scan lists are enabled
DSP release notes
* minor enhancements to P25 PDU handling
Instructions:
Update the PC APP
Update the CPU
Update the DSP
CPU Release notes
DSP release notes
