163 base station help programming edacs
RubberDuck1980
Immokalee, Florida
I've tried and read watched videos and I'm going insane. Please help. Want to program Collier County Florida edacs system. I have the frequencies and the afs but an totally confused on the steps to take.
wtp
Port Charlotte FL
i sent a PM with some ideas to try.
the short on it is antenna dance to find a sweet spot.
look up to the top right of this page.
N8IAA
Fortunately, GA
Don't know what you expect to receive. The county has moved to a P-25 trunk system.
Best if you click on the blue Report button and have it moved to the Florida state forum for better answers.
RubberDuck1980
Immokalee, Florida
Some of it went to p25 not all but thanks anyway. I expected someone with the same scanner to explain what I'm doing wrong but apparently that's too much to ask...jeeze
wtp
Port Charlotte FL
if you set up the conventional system then the only ones left are the ones you can hear.
the 163 does not do digital. the engine sound is digital.
wtp
Port Charlotte FL
since the old analog frequencies and the digital ones are the same, there would not be anyone left to hear as no one would have two different systems on the same frequencies.
i hate to say it, but you will have to get a digital scanner.
and i gave you a list of things to use the 1633 to listen to. (PM)
wtp
Port Charlotte FL
Mr. Duck, i sent what might be the directions to program the scanner.
i have never had to program an edacs system.
Nasby
Ohio
If you are able to get it programmed, please let us know if you receive any activity. I’ve monitored the Collier edacs system off and on but have never heard a peep since they moved to the P25 system.
