American Electric Power (AEP) P25 WACN 92715
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Attach files
Nice! I wondered whether TDMA = phase 2 and FDMA = phase 1. All this time I just assumed I wouldn't be able to pick them up. Appreciate the responses, thanks!
Yes, T Next to the site name means it is a TDMA control channel, just as T in the mode column of the talk groups indicates it is a phase 2 talk group. At this point in time it seems most phase 2 systems have an FDMA control channel, with the rare exception of a few wide area power systems built with L3 Harris hardware such as AEP and Duke energy
mtindor
FMP24 PRO USER
Imagine an outage in an area not covered by the TRS, where you can't predict the outage and location 10 days in advance (which is basically any/all outages).
(7) At least 10 days prior to operating, AEP must notify all co-channel licensees within 113
kilometers (70.21 miles) of those areas in its service territory where use of the waiver
may be required
LOL.
mtindor
FMP24 PRO USER
Robbie1984
Kalangadoo, South Australia
You guys over there a very lucky that AEP are going P25 and building it out whilst still making it monitorable here in South Australia SA Power Network formerly ETSA Utilities migrated from their straight analogue VHF high band system which included crossband UHF high band channels about 7 years ago to the SA-GRN and have 28 allocated fully encrypted talk groups for their communications
mtindor
FMP24 PRO USER
That is a shame. Very useful to be able to know what is happening during an outage. at least I think so. There is another multi-state Utilities system here in the states, Duke Energy -- they switched to P25 Phase II (or are still working on it) over the course of the past couple of years, and everything thus far is 100% encrypted.
Robbie1984
Definitely very handy to keep track of then when they were on VHF especially during outages when my father was alive he use to do contract electrical work for ETSA before retiring he had a 10 ch scanner in his work bus that consisted of the local emergency channels as well as etsas work channel so he had an idea of what was happening if called up
mtindor
FMP24 PRO USER
A lot is done over data terminals now, so even though AEP has such a huge system, there isn't as much activity as there was years ago. and even years ago when they were on an EDACS system they used data terminals. But once they switched to the p25 system the typical voice traffic went down quite a bit. But during an outage, the trouble talkgroups are definitely active and linemen/etc are always verbally confirming with dispatch when a circuit is about to be brought online again after an outage. So, fortunately, there is still enough activity to determine what is causing the outage in my area (fallen tree took a line down, vehicle hit a pole, transformer blew up, etc).
Robbie1984
When SA Power had their VHF system operational prior to going fully p25 encrypted they would be communicating with their linesman and patrol vehicles to see which line had a fault or was damaged this was relayed onto their depot in Mount Gambier to allocate resources however voice traffic was short and sweet not consistently active like it would be over there
slayer816
NE Louisiana
SWEPCO Talkgroups Shreveport Area
5191 submitted as Shreveport Trouble (had to call their linemen out at work, saw the radio) even though it covers Bossier City.
5292 sounded like transmission trouble in TX (called "Western", then no answer, called "Dispatch", they answered and said Carthage PD reported a broken pole). Not sure what "Western" is.....
5203 sounded also like transmission trouble in Shreveport. I know it's in the db as the Lieberman PP, however they're talking about busted poles held on by a drop. At an address in Shreveport City (far away from the plant in Mooringsport).
Anyone else in the area monitoring?
mtindor
FMP24 PRO USER
Three new licenses in Louisiana
Colfax, LA (Grant) - 4226 Hwy 71
31.46486, -92.58977
854.9125
855.8875
859.8625
861.0875
861.9875
Many, LA (Sabine) - 1075 Middle Creek Rd
WSDY725
31.56894, -93.45541
854.1125
861.1125
861.4125
861.6375
861.9625
Verda, LA (Winn) - Hwy 471
31.74175, -92.76558
854.1125
855.8375
861.3625
861.6125
861.8875
gtaman
TACSAT
GALAXY 19 91.0° W
Any able to confirm that they can see Harris aliasing?
It is active here in Ohio
Alias is set up as OHXXXX
So Ohio radio id 2004567 shows up as OH4567
You will need a Harris radio to decode these.
I would the two digit state code will follow to other states ex WV,KY,TX etc…..
mtindor
FMP24 PRO USER
Yep, I see them for both AEP Ohio and Appalachian power and it’s probably the case for all of the systems
DSD plus, SDR trunk we’ll pick them up. I think DSD-FME also does
mtindor
FMP24 PRO USER
More new licenses for Louisiana (check post 1571 for the others)
Hineston, LA (Vernon) - Highway 463
WSDS839
854.1125
860.8625
861.2375
861.4875
861.8125
Hornbeck, LA (Sabine) - Powell Rd
WSDS632
854.8375
855.8375
857.8875
858.8875
860.7875
Leesville, VA (Vernon) - 200 Parish Line Rd
WSEG380
854.1625
858.7875
861.1875
861.6125
861.9375
Mansfield, LA (De Soto) - 972 Oxford Rd
WSDV766
854.3625
858.7875
861.1875
861.4125
861.8375
Robeline, LA (Natchitoches) - 111 Shady Grove Cutoff Rd
WSDS639
857.8875
861.0375
861.2875
861.5375
861.8375
Saline, LA (Natchitoches) - Parish Road 121
WSDV759
854.2875
861.0625
861.3375
861.5875
861.9625
So that's 9 new sites in total in Louisiana.
Mike
mtindor
FMP24 PRO USER
We also need people in the following areas to confirm these sites as being online (we know they are based upon what neighbor peers say but do not have actual realtime monitoring confirmation. I'm sure there are probably a couple of other sites in the various states online, or at least I imagine so.
If you are near one of these sites it would be great if you could check with DSDPlus or something like that to verify the site online, it's SystemID, Site ID, NAC, and active frequencies.
1F7 63.63 Chatham / Blairs / Dry Fork VA
1F7 69.69 Buchanan VA
1F7 91.91 Asher KY
1F7 92.92 Hyden KY
1F7 93.93 Buckhorn KY
1F8 39.39 Throckmorton TX
1F9 8.8 Cheyenne OK
1F9 47.47 Wynona OK
1F9 71.71 Fayetteville AR
1F9 86.86 Mena AR
Google Map
Look at the Site Research pages in the RR Wiki for your area
Mike
nd5y
Wichita Falls, TX
I got a RTL-SDR V4 last week and running SDRTrunk. Now I can decode TDMA CC.
I don't think I was ever able to find Cheyenne OK site (before they went TDMA) because too many others on the same freqs.
mtindor
FMP24 PRO USER
Awesome. I just worked your Throckmorton submission. Great to have that elusive one marked. I took the opportunity to update callsigns and locations on one or two sites and to update the 1F8 wiki stuff.
There are still "licensed" sites for 1F8 territory that haven't been discovered online, but they are sites for which I hadn't seen any FCC activity for some years now and likely will never be on / were replaced by other sites.
mtindor
FMP24 PRO USER
I remember a few years ago something wierd in Abilene TX area sites. Then I noticed today this one apparently moved from Abilene to Hawley. Check the location in the callsign link.
I'm aware of that one having been one that was going to move. In fact that was on my radar when I was in the DB a few days ago. But some of the freqs are diff on the new license, and somebody really needs to copy all the active freqs from that site from scratch again.
I did update the location in the RRDB to reflect Hawley. But despite it moving to Hawley, it looks close enough to still be called Abilene and I'm betting they probably still reference it as Abilene, so I left it as Abilene in the DB.
