lcat06
I am getting a SDS100 for use in and out of my vehicle. I need a recommendation for the rubber duck antenna. I am monitoring the AIRS p25 phase 2 simulcast system in the Birmingham area. Ideally the rubber duck antenna will be as low profile as possible without suffering a major performance loss. I also need an antenna for the sds100 to use in my car that I will attach to an NMO mount on my vehicles roof. I would like this to be as low-profile and look tactical as possible. I like the stubby antennas on police vehicles and like this design but I do not know if this will sacrifice long range scanning performance. I am also trying to monitor air band and federal frequencies. They both need to be very durable and high performing without looking obnoxiously large and intrusive. Thanks for the help!
lcat06
I also have a Rago fabrication mount on the back of the 4Runner if any antennas would fit on that preferably a stubby style.
IC-R20
LoBand Nation
This isn’t for ham though… that antenna looks like a 2m/70cm antenna
It doesn't matter. You won't be transmitting. It'll work from airband to 900 no problem.
lcat06
What about low profile like the Motorola shotgun shell style antennas would those work?
lcat06
Like the HAF4013? If I had this mounted on the roof of my car in the dead middle how well will it receive? How many miles? I don’t want a long antenna on my roof due to clearmace issues. Do I even need to have a antenna on my car if I wanted to use a rubber duck on the sds100? How well will that Motorola antenna work on the simulcast and then on the other frequencies I can put on other antennas of the same nature and use a duplexer/diplexer to have multiple antennas? Would that work
IC-R20
LoBand Nation
Yes those would work. I've used them before for 400 and 800 reception and they work reasonably well with a single antenna, I would only get an additional one for VHF if you wanted to receive that band and diplex them together, I've seen Stringers in Los Angeles do that. With the SDS radio you'll be fine for receiving simulcast.
lcat06
Okay so the Motorola antenna will work. What is my range with this? Do you think this would have a significant advantage over a Remtronix rubber duck antenna for use in the car? If I wanted to add other antennas and combine them how will I do that.
lcat06
Adding more antennas to expand my band coverage is what I mean. Or will that Motorola antenna pick up everything?
lcat06
Like I would want to receive mainly 800mhz simulcast but I want flexibility to go to federal bands and air band which is vhf. How can I combine these
lcat06
Gotcha.. so with a Motorola 800mhz antenna will that just be able to scan 800mhz or others? Do I need a separate antenna for vhf? How do I do this
dave3825
Suffolk County NY
If you get one based on performance with a decent amount of gain, you should get some decent range. Often the low profile/tactical antenna have less gain.
An antenna tuned for the desired band will usually yield the best results. A vhf antenna will not do great on 800 and an 800 will not do great on vhf. Best to get one for each band and use a diplexer which takes different band antennas and combines them letting you run one feed line to your scanner.
lcat06
Okay thank you for the help! The low profile tactical antenna has 3dbi gain while the one you sent has 2.1 I believe. I don’t know much about the concept of gain. Would 3dbi gain be enough? What would my range be looking like
vagrant
ker-muhj-uhn
California
- If you have a proper ground plane the Larsen 150/450/758 is a good choice.
- If you have a poor, or no ground plane mounting location the Compactenna Scan 3 is the choice.
Those other short nub antennas will work with very strong signals, but not as well as the two above. You could use a diplexer, or triplexer to connect two, or three nub antennas together to feed your scanner. You won’t need a diplexer with either of the above antennas.
! Before you purchase an antenna, experiment with what you have. If you’re satisfied with the result you win. They also make suction cup mounts so you could place a rubber duck on a window. That’s rather low profile.
dave3825
Suffolk County NY
I dont recall posting an antenna.
There are many factors involved so range would be hard to predict. Anything in-between you and the transmitting source would affect range. Hills, valleys, trees, elevation etc.
W4KRR
Coconut Creek
+1 for the Compactenna. I use one because it's only about 9 inches tall, so my SUV fits in my garage with no clearance issue. It's designed for VHF, UHF, and 800MHz bands. If you need to go with something shorter like the low profile "shotgun shell" style, keep in mind that they will receive poorly on the VHF band.
Those little low profile antennas are going to work OK on their specific band only. If 800MHz is the only band you want to listen to, then it would be an option.
They are not a high performance antenna. They are designed primarily for low profile, performance is secondary. If all you want is the looks, then go for it. But if you want something that works well, then it's not what you want.
If this is -only- for a scanner, get one antenna that covers what you need. Yes, you can install multiple antennas and multiplex them together, but that gets expensive. Get one antenna that does what you need. Mount it properly on the roof of your vehicle and enjoy. Since your SUV should provide a good ground plane for the antenna, get something like the Larsen mentioned above or the EMWave. It'll work well on VHF, UHF and 700/800MHz.
Skip the ham radio antennas. While they'll work, they are tuned for specific portions of the VHF and UHF bands only. You'll get better performance out of an antenna that is actually designed to work where you want it. Since AIRS uses 700 and 800MHz band, you want something that will cover that. The two above antennas will. Plus they'll give you some decent performance on VHF and UHF.
Remember that the antenna needs to be properly mounted. Permanent mount in the center of the roof is ideal. You want that metal plane under the antenna for it to work to it's full potential.
lcat06
What is a good amount of gain? The low profile one I’m looking at is 3dbi
