im using a small whip antenna on a magnetic base. The PD station is a few blocks away and im also able to listen to long island and northern westchester. Im going to try and change the control freq.
SRH-77 Diamond
whip antenna. Anyone have any suggestions on what else I can do? I'm not picking up any control signal for Port chester or any control signal for Metro-25/MTA.
Strong signal for Westchester P25.
Ryebrook and Rye still on 155.625 FM.
Guessing this one:I cant seem to find the antenna online? Do you have a direct link? Could be that the antenna doesnt handle the 700 band that well, but receives UHF better.
In the channels tab, under the system is LSM selected? I think i saw in a previous screenshot it is but i just want to make sure.
Also, i would recomend Downloading the system Directly From radio refrence as you have premium. You want to Import the Zone 3 Simulcast as thats what PCPD affiliates to. I would recomend importing all talkgroups first and then later on Locking out the talkgroups you dont want to listen to.
Guessing this one:
Diamond Antenna SRH77CA Diamond Antenna Dual-Band HT Antennas | DX Engineering
Free Shipping - Diamond Antenna Dual-Band HT Antennas with qualifying orders of $99. Shop Handheld and Scanner Antennas at DX Engineering.www.dxengineering.com
I'm using that antenna with both dongles. I do have a larger antenna I could try but I would think the whip would be enough?What Long Island are you able to listen to?
If your trying the control channel I posted earlier, that's the one you need to obtain signal on. I am on the system right now and the control channel for Zone 3 Westchester is 769.90625 as seen below.
SYSTEM:26E[622] NAC:015[21] RFSS:51[81] SITE:51[81] LRA:51[81] CHANNEL:1-145 DOWNLINK:769906250
Your using a small whip antenna. Are you using that one antenna with both dongles or does each dongle have its own antenna?
Assuming you are running Windows, look for a download called sdr-trunk-windows-x86_64-v0.5.1.zip on the releases page.Downloaded final version
I checked. I have that Version. I ordered a different dongle. R820Assuming you are running Windows, look for a download called sdr-trunk-windows-x86_64-v0.5.1.zip on the releases page.
hmmm. … maybe it looks different because you have a different brand dongle than I do.
