N8IAA
Paul, very interesting. What is the size? What kind of beltclip? AM/FM programmable in the UHF milair frequencies?
TIA,
Larry
TIA,
Larry
Doesn't that defeat the entire purpose of having priority channels/having priority enabled in the first place? Maybe I'm missing something, but if the scanner is locked up on a non-priority channel, and DND prevents it from interrupting to check the priority channels, then it's the exact same behavior as having priority disabled. What am I missing?![]()
TIA,
Larry
So is this a airband geared scanner?
FWIW, the screen has a "AM" icon on it......
Tim
While there are a few conventional channels in 800 MHz, the vast majority are trunked. Adding trunked is a "non-trivial" change and would result in a significantly higher cost...basically it would be a BC346XT, and we already have one of those. What is missing from the market is a full-featured conventional scanner with alpha tagging (AT).
DND on priority is an option (you can choose to use full priority). The #1 or #2 question on scanners with priority is "why does the audio drop out every 2 seconds?". This allows a second-tier priority that checks the priority channels without interrupting active reception. Since most radio exchanges involve 3-4 second transmissions, delaying until the end of a transmission to check for priority activity is an option we think many users will appreciate.
