I have both the 436 and 536 scanners which were bought shortly after they were released around 4/5 years ago. I don't have the clock resetting problem and have never used the scanners much on the bright led setting. Will I eventually experience both the "clock" and "dimming led display" problems or are these issues only associated with a certain percentage of these scanners?
If you avoid using the 436 and 536 scanners at the brightest display setting can you avoid the "dimming display" problem completely?
I have both as well, but got the 536 immediately and the 436 about half a year later. Never used either on high brightness.
The early 536 was so bad and dim I could not use it by the time the repair program started. It was on 24/7, but usually in one of the dim settings. Never had the battery issue.
Sent in at beginning of program and it has been great since. They also replaced the battery.
I have never had an issue with the 436, which also has run 24/7 but may have been after problems were resolved.
SDS100&200/536/436/WS1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
