BCD436HP / BCD536HP Repair Campaign
gordiebill
Ontario Canada
Shipping to/from Canada
Are there any Canadians on here that have shipped their scanners back for the repair.. When you got them back, did UPS charge you brokerage fees?
I got charged brokerage fees on a warranty claim once (not Uniden) and I didn't think it fair that I had to pay for this. I refused the shipment and advised the vendor to ship USPS. No problem what so ever getting it back via snail mail.
Would love to hear from fellow Canadians as to what their return experience has been. I can live with the clock problem if it's going to cost me money to get my scanner back.
I realize this is out of Uniden's control, so I don't fault them for it.
Thanks for any input;
Gord - VA3TWT
omrail
Leduc Alberta
Gord - VA3TWT
When i sent in my 536HP for the headphone warranty work it was shipped back to me with Fedex and there was no brokerage fees from FedEx to me. I was thinking the same thing back then that UPS would charge brokerage fees and was on the form then asking and bring that up. I guess it will be a mouth or so before I can send my unit in so it would be nice to hear from fellow Canadians. Hoping its the same this time
Robert721
Klein, TX
Got the 536 back but I continually get "SD card file error use Sentinel "clear user data" operation to initialize SD card." Problem is that didn't work. I write the to the card, nada, tried to update the firmware, nada. So what next. My mistake I forgot to take the card out before shipping.
wise871
N.W. Florida
Are you trying to write to SD card while its in the scanner? Do you have a external card reader to try? Also make sure you show all when clearing user data
Robert721
Klein, TX
I have checked several things and the last says the card is not formatted and I cant format the card. looks like the card is toast.
so yes make sure you remove the sd card!
MarkWestin
Caribou, Maine
When all else failed, I was able to format an "unformatable" SD card with my camera. My camera formats it to the "raw" file system, but then my computer could format it and I'm still using it.
kb8rvp
Michigan
BCDx36HP: BCD436HP / BCD536HP Repair Campaign
You can try this memory card format tool from Panasonic:
SD/SDHC/SDXC Memory Card Formatting Software | Download | SD Memory Card | Digital AV | Consumer Products | Support | Panasonic Global
And another format tool:
https://www.sdcard.org/downloads/formatter_4/
Mike
MStep
New York City
If you peruse the forums, you will find that there are several programs available that will format SD cards. I've tried quite a few of them--- sometimes when a card is a little "whacked out", one program may work where another might not. Surprisingly, I've usually had luck just using the format tool within Windows to format into FAT32. I then "stress" the card by writing and erasing several files to the card, then reformatting again and also doing a CHKDSK on the card. With a little patience and perseverance, most cards can be brought back to a stable, working state.
Robert721
Klein, TX
Tried the format utility in windows and the other and the windows say unable to complete the format and the other says the card is write protected. both show the card which is 4gb as 30.6 mb.tried the card adapter in the sd card slot and a direct insert in my card micro sd slot.
AC2OY
Belleville,New Jersey
I left my card in and when the scanner was returned I had no problems with the scanner and card.
NR that's what I was thinking. I followed their directions to the letter being "it's their show",I had assumed something else happened to the card. I'm sure after reformatting,he will be off to the races again.
Voyager
I'm glad I took my card out. Why would his card be fried now?
Coincidence. It just happened to fail at that time. For some reason the OEM cards aren't that durable. Yet the exact same cards from the same manufacturer seem to have a much higher durability factor.
I can't help but wonder if they got counterfeit cards from their vendor. I've gotten counterfeit cards from a well known retailer. (and returned them)
garys
Central Texas
A false write protect flag is a sign of card failure. I bought my first 536HP used and the SD card came programmed with information the seller loaded on to it. I used ARC536 and created my own "profile", which I tried to load. No dice because the card was write protected. I ended up using another card I had lying around and it worked fine.
AC2OY
I agree Voyager I need to pick up some additional cards for backup.
nr2d
Laurel Springs, NJ
I am using the original cards that came with each of my 2 536HPs. I have had no problems with the cards since day 1.
Voyager
Same here (no issues with the originals) but many people have had the OEM cards fail.
