BCD996XT Freq not showing on scanner display
NFR85
I programmed a bunch of frequencies in via ARC XT scanner software. For Nashua it displays it on the bottom near SO and GRP but the other frequencies it doesn’t show it. I have it labeled to what I’m listening to IE Lowell Fire.
NFR85
Tried that all I got was Miltary Aircraft ECT. The manual doesnt help either very confusing
hfxChris
Dartmouth, Nova Scotia
If you hold and push func + 6, does the scanner even confirm that it is cycling between display modes 1, 2 and 3? What does it say on the screen when you try and do that?
NFR85
it doesnt cycle unless I manually do it when i hold it on Mode 1 says SID: 7C25h-0001
CoolCat
The scanner must be in "HOLD" mode (not scanning) first before you can use the secondary function keys.
NFR85
Seems like its showing the freq on the bottom. I'll keep you posted
