Burlington County 700 MHz Project 25 TRS
joey123
nj
Just wondering is it my scanner or is it the ems channel not working right with the F1 patch
The audio sounds very low
rrpratt
Willingboro, NJ
To he honest, the only difference I see is clarity. Low volume still exists. And has been, to me, dispatcher specific. In other words where is your mic position???
howie38
Pemberton NJ
I wonder if their system has an audio voice meter. Maybe an automatic gain would be good to even things out.
trentbob
W3BUX- Bucks County, PA
So guys I just wanted to get back with my report from the riverfront at the Burlington-Bristol Bridge. The digital F1 dispatch is coming in with just poor modulation. You can hear it and it's not completely broken it's just poor quality. That is on North simulcast. I have a great RSSI number. Solid data transmission.
tonemaster
Burlington County, NJ
Some operators use a headset, some don’t. They have to be cognizant of the output, which they aren’t.
trentbob
Yes it is awful in the Burlington City, Bristol borough area. It's not just low volume but it sounds like it's not decoding well. Stark difference from the first day it went online when it was loud and clear on North simulcast. VHF doesn't sound so hot either.
w2xq
A source tells me he doesn't know if tower climbers have yet replaced the jumper at the top of the tower, as I mentioned before. He doubts it.
joey123
nj
I wonder if they going fixed the issue with the F1 patch to the new system
policefreak
Berlin, NJ
I'm sure it will get fixed it's just a matter of trial and error. I'm quite frankly just happy to have something on the 700mhz side. FWIW the Camden County simulcast of their F-1 sounds pretty terrible at times too.
joey123
nj
Ok When you listen to it on your SDs 100 do you get very horrible sounds on it when you listen to it And you can’t understand what there saying
trentbob
That's a good way to describe it. Both the 100 and 200. The actual signal itself is strong low RSSI but it just sounds like as you described with low volume. The tones are very loud so it's not as if you can just turn it up. The VHF high is also the same way.
As w2xq said it looks like it still needs work so we can look forward to maybe it improving
I was very impressed with the performance on North simulcast when it first started on the weekend, it was clear with good volume. The tones were little wonky but it was good.
policefreak
Berlin, NJ
Yes I do. Even on my Unication G5. Its not there on the analog. It was different yesterday and that was different than Saturday. Like I said it is a work in progress. It will get worked out.
