Can't Read/Write from/to SDS100 n' BCD436HP
donc13
Grand Junction, CO
At present, my ISP is Spectrum, but. I may be switching to Brightspeed.
It beeps, when I:
1. Turn it on
2. Go into MSM
3. Turn it off
When you reformatted the card, did you reformat as a FAT32 (or FAT32 ext)?
That filesystem type us mandatory.
Chris0516
Pittsboro, North Carolina
Sentinel is 'playing hooky', again. While I can change the target model. I can't do 'Clear User Data', on my SDS100. I re-formatted the SD Card w/o any errors.
tvengr
Well Known Member
Baltimore County, MD
In all of your posts, I haven't seen a mention that you tried a different cable. If neither scanner works, a bad cable is a definite possibility. Also, there is probably a write protect switch on the SD card adapter.
Chris0516
I haven't tried different cables, because. I got the BCD436HP working again, after. Sentinel started behaving again. I would agree with your mention of the Write-Protect switch, IF. I was not able to reformat the SD Card in Win11.
Chris0516
