jaymatt1978
I understand what you're saying Tom but with all do respect you haven't scanned Bergen County therefor the RR formula that used in all other counties in t he country DOESN'T WORK. Which is why the database is such a mess. With all respect to the DB Admins I can tell you they're dismissing DB corrections as duplicated information when it really isn't duplicated information.
I understand the backend programming aspect of RR and really appreciate the work the DB Admins do, it takes a lot of effort. However that being said people need to come to the realization the Bergen County section will never be as accurate as it can be, just because of the way the RR DBs are setup.
Everyone,
RR policy is that multiple towns / townships / villages / hamlets (whatever) which share a common frequency and squelch tone are not to have duplicate entries, but rather grouped under a single frequency/tone listing. This is due to the fact that a radio programmed with all of those duplicate frequency / tone listings could say "Any Town Dispatch" when in fact "Other Town Dispatch" is actually the agency talking. This would obviously be very confusing to many listeners. It also unnecessarily uses a lot of scanner memory as well.
If particular towns have the same frequency but different tones, then they are supposed to be listed separately.
If you know of unique frequency/tone assignments for any given agency, please submit that information using the "Submit" button so the area administrator can make the necessary changes.
I realize that some people prefer to see the database broken down so that each agency has a separate listing, but as noted above, this simply does not work well for the computer programming aspect of RadioReference. The current policy is a reasonable middle ground.
