DSD+ 2.254
matthewn1983
3 days and has frozen 3 times. My issue is that the Channel/Radio Group Count window freezes, but the DSD Event Log window continue as normal, but when i goto close the Channel/Radio Group Count windows the whole application freezes. On one occasion losing the DSDPlus.Groups file. At all 3 times i was monitoring P25 Phase 1 System being fed from SDRSharp->Virtual Audio Cable into DSD.
slicerwizard
Toronto, Ontario
Had it happen to me overnight. I noticed that the groups window had 126 groups and the radios window had 2845 radios, which are the highest I've ever seen either of those numbers get. Makes we wonder if some limit is being hit. What numbers are other freezers seeing? Are non-freezers seeing higher numbers?
radiotrack1
Lumberton, NC
Love the new feature, but is there a way to change the column width or the window width of current radios window?
Forts
Ontario, Canada
My groups window over 4 hours sits at around 100-120 on average. My radios window is in the 500-700 range depending on time of day. Zero freezing issues here so far.
cg
Connecticut
Hover over lower right corner of window with the mouse and drag the yellow arrow that shows where you want the window width/height to be. The column width appears to be automatic based on alias lengths.
chris
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
On the freezing issue, I have not had one freeze whatsoever. I'm running one Airspy on a single CC, no audio monitoring, with my MaxAge on both windows set to 24h. Radios is currently at 549 count, and Groups at 65.
Muxlow
Super Secret
Middlesex County
DSD has been running since my last post with only the event and activity windows open no crash on Michigans P25 detroit site system that is insanely busy.
Just shut it down. Opened it back up and turned on the current groups/radios window and after 30 seconds locked up. Shut it down, everything including FMP24. Loaded back up same thing. WIll try a restart of the computer and see if that helps. But so far its for sure these 2 windows causing an issue on my setup atleast
Muxlow
Super Secret
Middlesex County
UPDATE
Reset the PC, loaded everything up including the 2 new windows. Ran fine for 30 mins on MPSCS detroit site then locked up
I do notice each time it locks up the last line shows Opcode=9 MFID=90 09 90 47 40 00 00 00 00 00 00
Not sure if that helps or anyone els has that showing too
Forts
Ontario, Canada
Well I don't know what's changed.... but I'm in the freeze-up club now too. Was sitting here for the last hour or so visiting a few P25 sites and it just suddenly started doing it. Freezes within 5 seconds of acquiring the control channel it seems.
Jay911
I just restarted mine and am still having no problems.
MFID 90 is Motorola. If my info is right, opcode 09 for Moto is Telephone Interconnect Voice Channel Grant Update. The LCN being announced is 16384, or 04-0000; is there such a channel in that system?
It'd be interesting to know the last opcode/TSBK for all you guys having lockups.
Forts
Ontario, Canada
So I just started it up again to see if I could get an opcode when it freezes.... and it's running just fine again. Go figure!
Jay911
I forgot to mention that I'm monitoring a Harris system. Forts, do you know what system flavor yours is?
Forts
Ontario, Canada
Motorola. I have another PC monitoring a Harris system and no issues there so far.
Forts
Ontario, Canada
Just froze again out of the blue after running almost 2 hours.
Opcode=5 MFID=90 05 90 40 80 40 00 00 00 00 00
IDEN_UP ID=0 Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
Sync:+P25p1 NAC:790 TSDU SYNC_BCST US=0 IST=1 MMU=0 MC=0 VL=0 LTO=-5h 2020/06/04 02:50 uSlot=3090
That was the last bit of data before she went belly up.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
mine ran all day today w/o any issues - but i was on a fairly small OBT trunk (285 radios/56 active groups)
I am still very much digging the radio ID / TG data windows. That feature alone is worth paying $25.
d
batdude
Moderator
I hate to double post, but oh well - I have a question that I can't seem to figure out.. a few actually. The picture below shows what I believe to be "PRIVATE CALLS" on the system. I have the appropriate boxes checked to enable routing of the audio for these... but I really don't see CC event log entries to support them "in use" --- i would get it 100% if they are all encrypted... therefore no audio (unless you turn that on separately) ---- but is there something I am missing in regards to hearing the PCs?
