If you have a confirmed control frequency and an LCN for one site on the system you can use the LCN calculator linked in the thread here to try and determine the frequencies & LCNs of the other sites based on the data from the site you have. Next, examine the FCC license(s) of the target system(s) (which you claim haven't been created yet?) to confirm the frequencies are listed there. Lastly if you're able to get within range of the neighboring site(s) to ultimately confirm your findings that's your best bet before making a database submissionjust trying to find out what the neighbors control channel frequencies are.
Frequency | LSN |
461.3875 | 1661 |
461.4 | 1663 |
461.4125 | 1665 |
Thx but how did you calculate that?935.0125 Base
935.1375 23
935.1875 31
935.2375 39
935.8750 141
936.0125 163
936.0625 171
936.1875 191
936.3000 209
936.3625 219
936.3875 223
939.5125 723
939.6625 747
939.8875 783
939.9250 789
I do similar with spreadsheets, but I'd recommend adding a conditional formatting on the frequency column and add the formula in this article, which will highlight any duplicate frequencies, instead of manually searching for them: How to Highlight and Find Duplicates in Google SheetsSince the list of frequencies is short I used the frequency calculator referenced in post #8. For longer lists of frequencies I find it faster to use Excel spreadsheets.
In any case I sort the frequencies in ascending order which serves as a self-check on the data. Duplicate frequencies are then easy to find and the LSN numbers also should be in ascending order.
Site1 | |
Frequency | Frequency config in DSD+ |
939.8875 | TIIInonStd,S1,1,31,935.1875,0.0,0 |
935.875 | TIIInonStd,S1,1,191,936.1875,0.0,0 |
939.5125 | TIIInonStd,S1,1,223,935.8750,0.0,0 |
936.3875 | TIIInonStd,S1,1,141,936.3875,0.0,0 |
936.1875 | TIIInonStd,S1,1,723,939.5125,0.0,0 |
935.1875 | TIIInonStd,S1,1,783,939.8875,0.0,0 |
Site2 | |
939.925 | TIIInonStd,S1,2,23,935.1375,0.0,0 |
936.0125 | TIIInonStd,S1,2,163,936.0125,0.0,0 |
935.1375 | TIIInonStd,S1,2,219,936.3625,0.0,0 |
936.3625 | TIIInonStd,S1,2,789,939.9250,0.0,0 |
Site3 | |
939.6625 | TIIInonStd,S1,3,39,935.2375,0.0,0 |
936.3 | TIIInonStd,S1,3,171,936.0625,0.0,0 |
936.0625 | TIIInonStd,S1,3,209,936.3000,0.0,0 |
935.2375 | TIIInonStd,S1,3,747,939.6625,0.0,0 |
TIIIStd,S2,1.2,31,935.1875,0.0,0 |
TIIIStd,S2,1.2,95,936.1875,0.0,0 |
TIIIStd,S2,1.2,191,935.8750,0.0,0 |
TIIIStd,S2,1.2,223,936.3875,0.0,0 |
TIIIStd,S2,1.2,723,939.5125,0.0,0 |
TIIIStd,S2,1.2,783,939.8875,0.0,0 |
TIIIStd,S2,1.3,23,935.1375,0.0,0 |
TIIIStd,S2,1.3,163,936.0125,0.0,0 |
TIIIStd,S2,1.3,219,936.3625,0.0,0 |
TIIIStd,S2,1.3,789,939.9250,0.0,0 |
TIIIStd,S2,1.4,39,935.2375,0.0,0 |
TIIIStd,S2,1.4,171,936.0625,0.0,0 |
TIIIStd,S2,1.4,209,936.3000,0.0,0 |
TIIIStd,S2,1.4,747,939.6625,0.0,0 |
TIIIStd,S2,1.2,141,935.8750,0.0,0 |
TIIIStd,S2,1.2,191,936.1875,0.0,0 |
