DSDPlus2p523
United Kingdom
Hi Gent I haven't updated my dsdplusFL for a while now . Today I try to extract the file with both winZip7 and WinRAR and getting Lame_enc.DLL is missing in your computer which isnt the case . Have reinstall but still having the same issue. Am using Windows 7 64 bit OS . Anyone have any idea as to how to resolve this ?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Are you seeing lame_enc.dll in your DSDPlus root directory as it should be? If not, check your DSDPlus\DLLs folder for it and copy it to the root directory. Even if you're seeing it in your root directory, take the same measure in the event it became corrupted somehow. Repeat for any additional file it may ask for
Have done that and still having the same issue.
Have you download and saved the BASE files through DSD+? If so delete your Lame file and replace it. If you haven't then when you get it working I highly recommend you do this each time they update.
Whiskey3JMC
Here, I zipped up the lame_enc.dll confirmed working with my DSDPlus install. Extract it into your root directory, choose "replace" if prompted to. If that doesn't work for you, not sure what else to tell you
  • lame_enc.zip
United Kingdom
NET error ? Still can't get lame_enc.DLL to work . Have tried replacing it with the base file
Downloaded it again
Updated computer
What else can I do
Nothing seem to work at this moment. Wanted to send pic but image is too big
dave3825
Suffolk County NY
Use Windows Snip
Load it up.
select rectangle
Take pic, then right click on pic and choose copy, then come here to message and right click, choose paste..
dave3825
Suffolk County NY
United Kingdom
Downloaded it again
Updated computer
What else can I do
Did you download the zipped file from @Whiskey3JMC in post 5? And extract and place that in your directory?
Where is your DSDPlus located?
Yes downloaded the file and place in the directory . My dsdplus in on my desktop which gives me access to the files in the folder . Am using my phone to take photos and still can't get the pictures to resize.
United Kingdom
Downloaded it again
Updated computer
What else can I do
morfis
Extract the DSD files from the archive (I'd suggest somewhere simple like C:\DSD though I know some people have an aversion to using the root directory.
Go through the normal set up procedure of ensuring you have the latest base files etc EXTRACTED to your installation directory
Running it from the archive (which is what you appear to be doing) is rarely the best option for any software.
Once done show us the batch file you are using to start DSD
As others have said, use windows to create the screenshot. Much easier to get it a suitable size and will do away with the horrible lines you are getting by using a phone camera.
dave3825
Suffolk County NY
Look in your directory for this event file. Open it in notepad. Scroll to the bottom and look for these lines. Copy and paste in message. Be sure to remove your personal details on the line after DSD+/Fast Lane Release
The location in your picture does not reflect a directory on your desktop. Ensure your trying to start DSDPlus from the DSDPlus directory.
dave3825
Suffolk County NY
Your last pic indicates you might be launching DSDPlus.exe from a ZIP file. Most likely the zip file that downloaded to your DSDPlus directory when you allowed Dsdplus to download the update. You need to unzip the files and place them in your DSDPlus directory.
dkcorlfla
Orlando
I just checked my working DSDPlus and there is a file called lame_enc.dll in the same folder as DSDPlus.exe.
Not sure it makes a diff on Windows but on Linux lame_enc.dll is not the same as lame_enc.DLL
If the folder and start with batch file advise above does not fix it maybe try renaming to all lower case.
dave3825
Suffolk County NY
When one downloads a DSDPlus update, and goes to extract it, one should be prompted to enter their DSDPlus password to complete that process. Did you do that?
United Kingdom
Ok have copy dsd base files into c drive and extract dsdplus2p523 from there and still getting the same error as before?
