I finally got my sds100 and I'm having trouble I'm coming from sdr dongles and using sdrtrunk and dsdplus. So I put my zip code In and it's just showing way to much , since I've been using sdrtrunk and dsdplus i pretty much know what frequencies i can listen to and what ones I can't, so how do I program just the frequencies I want to scan through on the sds100? I just want to program in what I know has traffic and be able to just select that and let it scan.
Here is what I want to scan
#1 three P25 trunked control channels And these are control channels not alternates 152.6825,152.5825,152.0376
#2 These are the others and and I have the nxdn upgrade
453.6725, 154.8125, 151.6625, 155.8000, 155.7000, 154.4875. And a couple more.
So how would I program the sds100 to scan all those frequencies i get confused on having the p25 control channels in there and scanning those because sdrtrunk has to be locked onto the channel, OR is the sds100 like OP25 with the control channels?
#3 ALSO I tried making two favorite lists and tried to monitor or scan through both favorite lists but it'll only scan through one i was told u could scan multiple favorite lists at once is that true?
#4 I messed with sentinel and got it figured out at least with the basics, I tried proscan but it wouldn't detect my scanner.
But back to my problem how would I make the scanner monitor just those channels i have tried already and all I see is no TGID. Thank each and every one of you if you can dumb your answers down some so i can understand
