Getting the color code, SL, and time slot for a DMR frequency
Nojo6
Baton Rouge LA
Hi all, I work at this place which uses the DMR frequency of 463.4375 in East Baton Rouge, and I want to program my own radio which is the Motorola CP200d to connect to the frequency, but I don’t know the color code, SL, and Time slot. I’m not super familiar with DMR but I think that’s all I need, I already have the frequency, but need the rest. Could anyone scan the frequency and let me know the information to connect to the frequency? Thank you.
LouNawlins
Hammond, LA
Your best bet is to talk with whomever is in charge of radio communications where you work. Use of color codes, etc is primarily for privacy and to reduce congestion.
Nojo6
Baton Rouge LA
We get our radios preprogrammed directly from Motorola. So there isn’t someone who can decode the color codes, ect just by scanning on a police scanner or something?
K9KLC
Southwest, IL
Yes this is the best way to get the info needed.
Someone where you work has to know what the information is, they ordered the radios per licensing at your place of business.
All this being said, yes, if you get a properly equipped scanner, you should be able to tell all that information.
LouNawlins
Hammond, LA
Whoever orders the radios from Motorola either already had a order sheet with the settings, or can request it from Motorola.
As a former employee of Motorola, I know they take their clients privacy as a serious matter. But the person authorized to order/communicate with them should be able to get that information.
The other way is safecracking;
that is trying different combinations until you crack it.
Some scanners will do this automatically, but like Motorola, wont reveal the settings
Do you know the Call Sign?
Nojo6
Baton Rouge LA
I can’t find the Call Sign.
hill
Middle River, MD
Your radio may or not work on system.
If RAS enabled to keep rouge radios off the system you will hard pressed to get your radio on the system. A lot of systems have this feature enabled for obvious ressons.
You really need to get with the person in charge of your work's radio system, as you really can't add any radios without their approval with a written letter authorized it The FCC license has the maximum number radio and other stuff and your workplace is responsible for it all. You really don't want to get in trouble at work with you trying to add your personal radio.
Plus a hobby radio website isn't really the place someone should be consulting to add a personal radio to a work radio system.
hill
Middle River, MD
Forgot to add on my last comments.
With DMR each radio has an ID this ID shows up on all other radios when you transmit.
You would have no way to know radio ID format they use. Plus radio systems can be configured to only allow approved ids on them and could it could block ID not registered it. You could just get bonk and be unable to transmit or your radio can be inhibited and then it would need to.be sent to Motorola to unbrick and you may not get unbridled with it not being approved.
NeFire242
Nebraska
I would venture to say they do like hundreds of others do that are too lazy to keep track or are aware of what the capabilities and features for their radio consist of and so its, TS 1, TG 1, RID 1 for all radios.
That's not true, at my job we tell Bearcomm the basics of what we need and they program the radios with there info since they are rentals and the office has no idea what color code, slot or frequencies are in use, and we aren't licensed as we use a Bearcomm national license.
This is correct, but the person who ordered it for us doesn't care since the radios are only used for a few months.
sdr and the digital decoder on your computer give you everything you need on the screen for free. Just the cost of a cheap dongle.
Definitely the best and cheapest way, without taking the radio somewhere and having them read the programming for you, which would most likely cost more than the dongle/software.
K9KLC
Southwest, IL
Only going by what my personal experience has been with getting info for people. Thus far either a manager or someone higher up always had the information for the radios they were using, it's how we got the information to program additional radios on occasion as needed for the places I've dealt with. Obviously if they're rental radios this could be different. I tend not to get involved with places using rental radios.
