Help with Unication info
bobruzzo
W1AV
Cranston, Rhode Island
When I go to "Zone and channel setting" I dont have all of the 64 TG's that I originally chose and I cant find them. I am stuck here. I dont know why I dont have all 64 TG's that I originally chose after I downloaded from RR.
OK I am really trying. heres what I got...I first downloaded from RR the METRO zone.....it looks OK....I chose 64 talk groups that go with this location.
You need to stay in one place you moved from C1 to D, stay in C1 when you add it, we are done with the D tab, what you are doing is creating a new profile in D, but C is where you will build on the profile..
Because you are getting ahead of yourself, we need to do this one step at a time otherwise you will make it a lot harder
bobruzzo
W1AV
OK I need to back up cause I dont have all the 64 talk groups I chose. I deleted AGAIN.....I need to start new profile and go 1 small step at a time. So I started new profile. I am at the basic information setting screen. I am at E then tab over to E1....I will stop there....It is hard for me to memorize too much info.
You are in tab C1, you use the orange button top right and import the system. Your first entry looks just like the screen shot below. After this you STAY on C1, uncheck the all sites box at the top and only click on the first site by the red, do the same for the other four sites. At the end you will have six sites in C1...Once you have that message back.
bobruzzo
W1AV
I am STILL not able to delete the original profile which is wrong the program wont let me start over. What is the first thing I do after creating a new profile? I keep going in the wrong direction after I make profile.
Here is what I have in C1......its the WRONG data...this is an old one I did earlier that has ALL 5 RISCON sites.....I cant delete it and I dont know where to go from here.
I didn't ask you to delete it, we want it there, now look at post 85 and do what I told you starting at the single sites by the red line, one at a time. Bob DO NOT worry about anything else, we need to take this one step at a time.
bobruzzo
W1AV
OK I am at the C1 and I will pnly add ONE site, the METRO SIMULCAST.......there are 30 TG's in there. I am going to UNCHECK the encrypted TG's first then do I import to public resource or to profile? Too many choices!!!!
Just import all of them, we will correct it later.
bobruzzo
W1AV
ok imported to public resources......
YES this is what I have
Okay this will work, but it is easier if you had imported all the talk groups rather than trying to add one later. but okay. Now go to tab E and you should see one profile in there, let me see what you have.
Then highlight Profile 3 and click edit at the bottom once the new screen opens take a screen shot
Great, now click on add and select from Add System from Resource and select all sites you added in C1
