StevieB
External speaker
Why use a 2.5 mm line out instead of common 3.5(1/8)?
Blew the dust off my BCD-396T to get it ready for local airshow and was listening to some local conventional PS. The squelch tail was annoying and was curious if Uniden has ever tried applying tone to solving the problem?
And no, I haven't got my HP-1 yet. After cruising the rr.com db for my areas of interest, I'm not interested in an HP-1 yet. I'm busy contributing geotag information, though, and when you early adopters get all of the bugs out of it, then I'll think harder about it.![]()
As Viper43 stated above there is always the chance Uniden might add some additional features later on via firmware updates.
Marshall KE4ZNR
:roll:
With this product Uniden has done away with a lot of previous useful scanner features..
I guess I'm wrong, let me check the Uniden site for the Uniden Software for the 996XT.
What bugs are you talking about when you say. "....when you early adopters get all of the bugs out of it, then I'll think harder about it..." ???
There are two kinds of 'bugs' I'm talking about. The first are problems with the radio and the database system, one was just reported and fixed in very short order. It was a bug in the way Uniden's custom rr.com db processing software interpreted a 'rebanding flag'.
...the other are holes in the rr.com db that impact how location based scanning works. I was reading a mini trip report from someone who took a radio from CT to MA and had issues with MSP. I know for a fact that my state is pretty sparse with geotags. Much of the tagged data is simply inheritance from the county geotags. The result is that city municipalities, local attractions, etc are enabled county wide.
...let me say that none of these issues are deal breakers, but thy detract from the overall experience.
For now, instead of learning a new radio, I'm trying to geotag all of my 'local' systems. Then I'll branch out to other areas of California.
how do you shut off location control ?
Where can I purchased the cable that would go to the Home Patrol to a GPS unit and what is the cable called a direct link would be greatly helpful to a non tach such as myself.
Thanks !!
Tony M.
My understanding is that such a cable isn't available yet. Looks like the unit uses the same serial cable as the recent Uniden radios. So if you have a 246, 330, 396 or 996 radio, you can use the programming cable. But.... You'll also need a null modem adapter between the DB-9 between the cable and the GPS.
I like the point you make about groups not included in the database. I am a novice and have ordered the HP-1 just for that reason. But just because I may be a novice doesn't mean I wouldn't find unknown groups interesting. Many years back I had scanners and they were a lot more user friendly. Little more complicated now and just don't have the time, so I am hoping this HP-1 will be the ticket.One of the problems I see is Radio Reference doesn't publish unknown talkgroups. This is for both the XT and HP-1. Many users have submitted information on new Trunk Systems like Control Channel, Site ID, etc. But RR doesn’t publish unknown talkgroups. Last month I submitted a new trunk system in my area with 70 talkgroups. The only reason they were not published was the fact they have not been ID yet. I think unidentified TG should be published to allow other users to help ID these groups. This is even truer when it comes to the HP-1 which does not have search capabilities. But then again, the HP-1 is more for the novice user.
