crevatis
Does anyone have the previous firmware? This update turned a decent scanner into a $700 piece of garbage. It barely receives UHF signals now.
I'm seeing any evidence of it being back. Holding on one site and signal bars are absolutely solid.Buddro, Does it appear to you that this WF update puts back in the Housekeeping that was removed or reduced before?
Is it possible you are overloding the front end or you have desense? -60 db is pretty high. Try turning on the attenuator for that system.Here's what its doing on the neighboring SmartZone system with digital voice. No calls during the :17 sec period, just regularly jumping off the cch.
Yea, this radio is actually doing a fairly decent job on the system - Unitrunker is better however. The "housekeeping" also occurs with a SDS100 when using a Remtronics antenna inside a vehicle, within the service area of the system, with or without attenuation enabled. The SDS100 is almost unusable as most transmissions fail to complete before digital breakup. Used to work great before the firmware upgrade. To clarify, the SDS200 is located outside of the service area, so likely not receiving as many subsites simultaneously as the SDS100 does when in the service area. There is a Stridsberg preamp in the line, otherwise there would be no usable signal from the outside antenna. Attenuation on the SDS200 brings the signal down to ~105 dBm, still have the housekeeping.Is it possible you are overloding the front end or you have desense? -60 db is pretty high. Try turning on the attenuator for that system.
Was that supposed to say "NOT" seeing...I'm seeing any evidence of it being back. Holding on one site and signal bars are absolutely solid.
Yes. I thought you were a mind reader.Was that supposed to say "NOT" seeing...
That made the signal even weaker. I really just need to find a way to get the firmware that worked loaded again.
Did you change your profile from the sds100 to your sds200 properly? Or do you use exactly the same profile on both?I updated my SDS100 and SDS200 with the new firmware. My SDS100 now blows with Simulcast systems and SDS200 does fine. Should I revert back to previous firmware version or should I try other things?
You are assuming that the RSSI indicator / measurement is working correctly. As I mentioned previously, this radio (SDS200) is not really having issues as it is located outside the the simulcast cell's service area, thus likely only receiving signalling from one subsite most of the time. When the SDS100 is connected to the same antenna system, it performs similarly. However, if that same SDS100 is moved into the system's service area - in view of multiple (powerful) subsites - this is when the fun happens. Most transmissions begin to break up and are dropped. The DEC count goes from zero to numbers in the hundreds when this occurs. Unitrunker does not have this issue in the same vehicle, and I suspect my XTS will not either. The SDSs did not behave this way prior to the firmware update as they worked perfectly fine on SmartZone systems.The attenuator will reduce the signal 20dB in the 800MHz band. If it went from -60dBm to -105dBm it is a 45dB reduction that indicate some kind of RF issue from overloading. If any filter or IFX setting works it should probably give a signal level in the -85dBm region when it is interference free.
/Ubbe
