SDS100/SDS200: How can I go back to the previous firmware
crevatis
Kenosha, WI
Does anyone have the previous firmware? This update turned a decent scanner into a $700 piece of garbage. It barely receives UHF signals now.
pro106import
Milford, Ct. perched high above Long Island Sound
Before you revert back, try changing the modulation from FM to NFM or vise versa. Also, try increasing the freq. 2.5KHZ. So if the freq is 460.2125, make it 460.215. I had to make these adjustments, and my UHF is better than ever. Equal to my Whistler scanners now after the new firmware. And I can set the squelch closed now to setting 2 and the radio scans and UN-squelches even with the weakest signal.
crevatis
Kenosha, WI
That made the signal even weaker. I really just need to find a way to get the firmware that worked loaded again.
crevatis
Kenosha, WI
However that did lead me to investigate with the waterfall. It looks like in my case it looks like its off frequency slightly in the other direction. If I could adjust it maybe 1KHz lower, it would probably fix it. Unfortunately, I don't see anyway to do that.
crevatis
Kenosha, WI
This is supposed to be on 461.925, but is slightly high. Came in great before the update and still great other the 536. Changing it to 461.900 would be too lower. Wish there was a middle ground or better yet a way to tune the scanner on this band to put it back on frequency.
gary123
there is a thread about addressing the off frequency condition seen in some scanners.
Remember too that the waterfall may not be 100% accurate on the center frequency.. Also there is no guarantee that the transmitter being received is on frequency either. Finally there is a possibility that the system being monitored is using a .00625khz step. Either way being able to adjust the scanner to a known on frequency reference is highly desirable.
maus92
OCMD
Here's what its doing on the neighboring SmartZone system with digital voice. No calls during the :17 sec period, just regularly jumping off the cch.
maus92
OCMD
Is it possible you are overloding the front end or you have desense? -60 db is pretty high. Try turning on the attenuator for that system.
Yea, this radio is actually doing a fairly decent job on the system - Unitrunker is better however. The "housekeeping" also occurs with a SDS100 when using a Remtronics antenna inside a vehicle, within the service area of the system, with or without attenuation enabled. The SDS100 is almost unusable as most transmissions fail to complete before digital breakup. Used to work great before the firmware upgrade. To clarify, the SDS200 is located outside of the service area, so likely not receiving as many subsites simultaneously as the SDS100 does when in the service area. There is a Stridsberg preamp in the line, otherwise there would be no usable signal from the outside antenna. Attenuation on the SDS200 brings the signal down to ~105 dBm, still have the housekeeping.
lkas
Cheektowaga NY
Mine did same thing on new firmware on two different p25 systems. I flashed old firmware back and it is back to normal.
  • sds100.zip
donc13
Grand Junction, CO
I updated my SDS100 and SDS200 with the new firmware. My SDS100 now blows with Simulcast systems and SDS200 does fine. Should I revert back to previous firmware version or should I try other things?
Did you change your profile from the sds100 to your sds200 properly? Or do you use exactly the same profile on both?
hey
Lewes, Delaware
OK fellas I need some help here my SDS200. I cannot flash it back. I tried everything I even wiped it clean and I cannot get the film where to update on the SDS200.
buddrousa
Others here have already done this and it works the old firmware is here you just have to get it from a user. The directions are here they were posted by UPMan you just have to find the post and follow the directions and not skip or get the steps out of order.
Ubbe
Stockholm, Sweden
The attenuator will reduce the signal 20dB in the 800MHz band. If it went from -60dBm to -105dBm it is a 45dB reduction that indicate some kind of RF issue from overloading. If any filter or IFX setting works it should probably give a signal level in the -85dBm region when it is interference free.
/Ubbe
maus92
OCMD
/Ubbe
You are assuming that the RSSI indicator / measurement is working correctly. As I mentioned previously, this radio (SDS200) is not really having issues as it is located outside the the simulcast cell's service area, thus likely only receiving signalling from one subsite most of the time. When the SDS100 is connected to the same antenna system, it performs similarly. However, if that same SDS100 is moved into the system's service area - in view of multiple (powerful) subsites - this is when the fun happens. Most transmissions begin to break up and are dropped. The DEC count goes from zero to numbers in the hundreds when this occurs. Unitrunker does not have this issue in the same vehicle, and I suspect my XTS will not either. The SDSs did not behave this way prior to the firmware update as they worked perfectly fine on SmartZone systems.
