I recently got an SDS100 and noticed that the audio intermittently cuts out for a half to full second as the Dispatcher's digital voice is relaying run information. I first noticed this in Washington state | King County | PSERN | NORCOM | Fire Dispatch 1 (TGID: 1399) and again with Ocala Fire Dispatch when I was in Orlando. It makes it almost impossible to hear the street address. I have tried it with Priority or DND turned on and off.
It broadcasts as expected when it shows NAC: 3A5h in the lower right-hand corner, P25P2 shows immediately under the date at the top, and I see five (5) connectivity bars. I noticed that when the audio cuts out the display shows P25 NAC: 3A5h in the lower right-hand corner and zero (0) connectivity bars. See the two "screen captures" below.
Any idea why that's happening and/or how what configuration setting can prevent that from happening? Thank you!
You will soon get responses asking for the exact system that you're listening to and your hometown County and state. Also check to see if there's any priorities on,
If I can make a suggestion and let us know how this works out for you.
On the radio itself with the keyboard so as you can get real time results instantly. Follow these steps, Hit menu, scroll to settings and hit the, control knob, scroll to site NAC operation and press control knob. Select ignore sight NAC with control knob. Press avoid once and monitor your system and see if there's an improvement.
Would you please report back to us and let us know if there's an improvement in performance? Thanks.. Bob
