Java program to decode DMR
Just tried it out. Unfortunately, I think the call alerts are backwards.
I called 6002 from radio 6001 and it said
17:05:48 DMR Data Frame
Slot Type : Colour Code 10 Idle
CACH : TACT Ch 1 First fragment of CSBK
Target Address : 6002 Source Address : 6001
Preamble CSBK : CSBK content 1 Blocks to follow
Slot Type : Colour Code 10 CSBK
CACH : TACT Ch 2 First fragment of CSBK
CACH : TACT AT=1 Ch 1 First fragment of CSBK
Call Alert from 6002 to 6001 (0000000000000000)
CSBK : CSBKO=31 + FID=16
Call Alert ACK from 6001 to 6002 (1001111100000000)
CSBK : CSBKO=32 + FID=16
Notice the Target Address : 6002 Source Address : 6001 but it says: Call Alert from 6002 to 6001 (0000000000000000)
I apologise if I wrote it wrong in my previous post.
matthewn1983
Can anyone shed some light as to what this Unknown CSBK/FID is.
Screenshot = http://i.imgur.com/GYtuxZt.png
Connect Plus Trunked system, UHF 450-527.
Unknown CSBKO=12 + FID=6
Now at the bottom that particular radio id belongs to a bus company, not sure if its related to this message.
IanWraith
ianwraith@gmail.com
Hi Matthew
CSBKO=12 is a PDU associated with some Capacity Plus systems. Its purpose and contents are as yet unknown and I would appreciate any help from anyone who fancies looking into this.
Note that it doesn't appear on all Capacity Plus systems.
Regards
Ian
cg
Connecticut
I am setting up a remote monitoring location to use the various software decoding programs from my home. I want to use the stereo microphone input with discriminator audio on one side and speaker audio on the other. Is there a way to split the input audio in DMRDecode into a left and right side? I don't know if I don't see it on my desktop because it is a mono mic or because the program doesn't allow it.
All set with Unitrunker, DSDPlus, & TRUNK88, just need to figure out this one.
chris
mrpurrfect69
Hi guys,
Question for you: Looking on the info on dmrdecode relate to what I'm listening too is a cap+ network on my sdr receiver here in the Uk, my question is that is they some software that will actually follow the calls like trunkveiw from the control channel or is it a case where I have to manually search for the other channels that are connected or linked to the main cc channel if that makes sense ???
EricCottrell
Boston, Ma
Hello,
I suspect CSBKO=12 is related to data transmissions. A bus company is likely have AVL or other data transmissions. The Ack Response Packet is in response of Radio 276028 sending data to a system device.
73 Eric
K
kubaval
Guest
Hi, it´s from IP Connect Plus System, UHF 450-469 MHz.
I hope this helps any one.
Group Voice Channel User LC
Service Options : Non-emergency/Privacy Enabled/Broadcast/OVCM Call/Priority 2
Group Address : 15355 Source Address : 10503
Unit to Unit Voice Channel User LC
Service Options : Emergency/Broadcast/OVCM Call/Priority 3
Target Address : 16575 Source Address : 11508
Unknown Full Link Control LC : FLCO=51 + FID=145 11111111110110000110111000110011100001001010100000001001
Unknown Full Link Control LC : FLCO=51 + FID=220 11111111111111000111110001001100111110000011010100000110
Unknown CSBK : CSBKO=31 + FID=16 0000000000000000000000000000000000000110000000000000000000000100
R_3_4_DATA (data block serial number=0)
01000101000000000000000000101011000000000000111100000000000000000100000000010001011001000000011000001100000000000000000011001111
R_3_4_DATA (data block serial number=1)
00001100111111111111110011011111000011111110010100001111111001010000000000010111010011011100011100100011111111110000000101000001
73 Jim
artee99
Hi everyone.
I have problem with decoding any digital system on my computer.
It seems to be a problem with sound card.
Can anyone recommend tested USB sound card taht i could use with my laptop?
I tried DSD on other computer and it works. So it has to be sound card problem.
Thank you for any help
cg
Connecticut
Doing the decoding takes quite a bit of computer horsepower. It may be that the fault is with the CPU and not with the sound card.
You should include your laptop specifications.
chris
artee99
I have DSD working good on Pentium D 915 machine. Laptopo is faster with Pentium Core2Duo T8300 and DSD is not working. It must be something with sound card.
Laptop is a DELL M4300.
chris
artee99
I've tried to run on another computer with different SC. Programm won't run. I got message that there's some class missing. It's Windows 7 32 bit. Is this soft works under Win7??
IanWraith
ianwraith@gmail.com
DMRDecode build 73 is now ready for download from the usual place ..
DMRDecode Download
New features include mobile side and direct (simplex) DMR decoding. Note that although this works I'm still not happy with the speed from the frame acquisition code and this still needs a lot of work.
As ever comments and bugs to this forum please.
racingfan360
Thanks for your continued great work on this project Ian. I can confirm accurate decoding of colour code on mobile subscriber DMR signals. While the DCC is displayed in the lower window, is there a chance of adding the decoded DCC to the quick log / log file to a future release?
Cheers
Jim
IanWraith
ianwraith@gmail.com
Hello Jim
Glad it is all working for you and thanks for the kind words.
Do you want it so that if a DCC is found on the mobile side or on a direct (simplex) link then that is recorded in the quick log ?
Regards
Ian
racingfan360
I think it would be good in both logs if possible: I don't think it appears in either atm. I just get the series of DMR Voice Frame (MS) so far. In DSD+ the DCC appears as a set of 3 DMR MS DATA CC=x VOICE Header strings on call initiation and a DMR MS DATA CC=x TLC string on call termination.
In due course if it were possible to add decoding/logging of source and destination ID's that would also be fantastic.
Let me know if you need anything tested.
Thanks again for all your work on this......you have made an enormous contribution to DMR decoding, and to a large extent kept scanning alive IMHO.
Jim
IanWraith
ianwraith@gmail.com
Hello Jim
I think you might have just been unlucky. The frame acquisition code isn't brilliant and I reckon 50% of frames are missing in MS/Direct mode. But monitoring a mobile side channel with users about 5 miles from me a short while ago I saw ..
18:10:15 DMR Voice Frame (MS)
18:10:17 DMR Voice Frame (MS)
18:10:25 DMR Voice Frame (MS)
18:10:26 DMR Voice Frame (MS)
Group Address : 1015 Source Address : 16448250
Service Options : Non-emergency/No priority
Slot Type : Colour Code 8 Terminator with LC
18:10:28 DMR Data Frame (MS)
18:13:41 DMR Voice Frame (MS)
18:13:51 DMR Voice Frame (MS)
18:13:52 DMR Voice Frame (MS)
18:14:09 DMR Voice Frame (MS)
18:14:10 DMR Voice Frame (MS)
18:14:11 DMR Voice Frame (MS)
18:14:11 DMR Data Frame (MS)
So mostly voice frames but some data also.
Regards
Ian
artee99
Can anyone tell me schould it work on windows 7? I can't run it on 32 and 64 bit version.
