Jk antenna problems
prcguy
Basically yes. If you have the type of mount where the coax attaches with lugs then its real easy to tack a capacitor across the coax at that point. If your mount has a coax connector you would have to find a point where you can stick the capacitor from ground to the hot side of the mount at the base of the whip.
prcguy
Thanks prcguy. Wish I was knowledgable enough to do that. Are you saying to solder them so one end is connected to the top of the mount and the other to the bottom?
