BCD436HP/BCD536HP: LCN FINDER (need help)
scanphreak
Good day all,
I've read the older threads, all most from 2015, and I think things have changed with LCN FINDER since then. For example back then I believe there wasn't a 'save' feature in the scanner when pressing F+SYS to get out of the finder. I have just purchased the DMR key and I'm trying to get the LCN for a 5 frequency XPT site. I've programmed everything in to a site, and went to LCN FINDER and so far it's found 1/5.
When I press F+SYS it's prompting me if I want to save, and I do save.
My question is NOW WHAT??? It saved one, I'd like to find out what that 1 LCN is. All of the other old threads do not explain how to retrieve that information.
Can someone please lay out step by step how to review the stored LCNs in the scanner?
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
From the radio itself, navigate to system & site in question (if you don't know how to do that, reply back)...
Choose "Set Frequencies"
Choose frequency in question and press "E"
Choose Edit Frequency but do not change the frequency. Instead press "E"
"Input LCN" appears. If LCN finder finds the LCN it will appear here
If no LCN found for frequency, LCN will appear as '0' here
Hope this makes sense
Reconrider
Inside the Galaxy
Radio Galaxy
I don't have a 436, but I do have it's daddy, the sds100.
On my sds100, I go to:
Manage Favorites > Favorite Name > Review > System Name > Edit Site > Site Name of whatever you LCN ran > Set Frequencies.
Go through each of the frequencies in there and look for the LCN you want to verify.
Click the frequency > Edit Frequency > Press Enter. The Input LCN should be on the screen now.
If you see 0 = it's likely that wasn't the one that you verified.
Whiskey3JMC
Or via Sentinel & assuming you "read from scanner":
Edit > Edit Favorites List
Choose FL and click OK
Choose system & site in tree menu structure to left.
LCNs will appear a where shown
scanphreak
Thank you everyone....
I went to the Set Frequencies and found that the LCN 0 had been replaced in one of the frequencies to LCN 2 and the others are still 0. 1 down, 4 to go, it might take a while to get them, but this is a start.
Reconrider
Inside the Galaxy
Radio Galaxy
What I did was set my scanner to LCN search at night and then with morning traffic, it will be popping for shift change
hiegtx
Mentor
Dallas, TX
If the system is not busy, then it can take a while to identify all of the LCNs.
Two things to remember:
If you identify one of the LCNs, be sure that you either manually edit your file in Sentinel (or whatever programming software that you use, such as ProScan or ARC536) so that the LCN is saved.
Also, if you restart the LCN Finder, when you do so, all of the LCNs will be rest to zero, starting all over again. It will not 'remember' that LCN 2 (from your earlier session) was found. It'll be reset as well to .
Carbuff
Warren County Illinois
I have found several confirmed LCN on my sds200 most of them I don't have a clue who are, I do know some are farmers I hear them mostly during planting and harvest time and some city transit bus
R0am3r
Salt Water Conch
Oneida County, NY
In my experience, the LCN Finder doesn't work for XPT systems. Set all the LCNs to 0 and see how it works out.
scanphreak
This system is a casino, so it's got traffic both day and night. But so far I'm only finding 4 talk group id's and it found the once LCN. I left it on for about 3 or 4 hours with several hits but it never picked up any others.
scanphreak
got it... After I jotted down which LCN captured, I went back and saved it in the scanner. This is how I have it now.
451.3250 LCN 0
451.7250 LCN 2
451.9375 LCN 0
463.6500 LCN 0
463.9750 LCN 0
Reconrider
Inside the Galaxy
Radio Galaxy
Yeah same here. Took me HOURS upon hours to get an LTR system only to confirm they never updated the numbers lol.
But it's still fun knowing I did the work.
Ubbe
Stockholm, Sweden
Try setting them to 1-5 in frequency order, as the LCN 2 seems to suggest that.
You can always enter all frequencies in a OFT system where it doesn't care about LCN's just to check what TG's there are in the system and how much traffic there are on the different frequencies, if you program each single frequency in a separate site with an individual name to each site.
/Ubbe
