Macon/Bibb FD moves again, PD coming soon
mjbjr
Macon,Ga USA
Thanks Mike
On another note,Ive got those TG put in and the police (or So )whatever you call it plugged in. Not hearing anything. I also had a staewide SO in but it would stop on it but no traffic so I deleted it. Im assuming we just dont have frequencies
RRR
OFFLINE
USA
"Bibb City" is in Columbus-Muscogee county
mjbjr
Macon,Ga USA
What you dont see is "Macon-Bibb City services". but thats is a great point of noticing. I have a friend (that has a friend) who says he can probably get the frequencies for me. But that might be today or next month,I dont know when.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The Macon-Bibb City Services frequencies came from the Pro96Com files that were sent to me. They also match the old analog system so I'm pretty sure they're correct. You should probably check your programming and make sure you're using ID Search instead of ID Scann
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Sorry but they're not mine to share. One of the participants on this thread made them available to me so I could get the database fixed.
Hopefully he'll see this thread and reply.
charlesdotcc
Falls Church, VA
Hi guys,
Yeah mjbjr - I'll send you a PSREdit file tomorrow like I did before. Like Mike said though, the database should now be right so I don't think its the wrong frequencies... Oh, I think I see what the problem is mjbjr - it looks like in that screenshot that you added the new talkgroup IDs under the city services system, but they did need to go under the "Central Georgia Interoperable Regional Radio System" instead. The city services system is the old one they were on before, the Central Georgia Regional one is new Harris system.
mjbjr
Macon,Ga USA
This is what i see under "Central Georgia Interoperable Regional Radio System" . If I add the 1st pic alone,the scanner says nothing enabled. Now the second pic,The FD,I can pick it up clear but of course I need the SO.I dont see anything that says PD or SO
mikewazowski
Staff member
Forums Manager
Oot and Aboot
For the Central Georgia system, go here: http://www.radioreference.com/apps/db/?sid=7748
For the Macon-Bibb City Services system, go here: http://www.radioreference.com/apps/db/?sid=7928
Once you're at the right system, look for the grey tab just above the blue system name labelled "Submit"
Click on that and you'll be sent to the submission page for that system. Enter your confirmed data there and it will be placed into the queue for a DB Admin to work.
Once it's worked by a DB Admin, it will be there for everyone to use.
charlesdotcc
Falls Church, VA
Ok mjbjr - here's a PSREdit file you should be able to load on your scanner and start getting SO traffic. You'll need to unzip the file first, open the .bin file in PSREdit, and upload to your scanner. Give it a try and see if it works.
@MikeOxlong - I think we're still working on getting to a place where we can confirm and submit.
-Charles
  • Pro106 - 4.17.2014 - Macon_Bibb P25 file for MJBJR.zip
mjbjr
Macon,Ga USA
That worked..weird,I dont see any of this on my end in PsrEdit. Must be a harris thing but dispatch is real scratchy when talking,but the deputies are clear.
charlesdotcc
Falls Church, VA
No, you're not going to see that in PSREdit right now if you imported the data from RadioReference, because the talk groups are too new to be in there yet. @maw just posted them to the forum here yesterday, and we've added them manually to what was pulled in automatically through RR so we could get you up and running and test them out.
At some point someone should verify his results and submit the new info for inclusion to the database, hopefully along with the names for the talkgroups. So far it just sounds like we only know 104 is NCIC. I'm guessing 100 is dispatch, but I'm just guessing.
RRR
OFFLINE
USA
Just FYI, on the old system, TG 104 / 3609 is regular PD communications, I have not heart anything pertaining to NCIC, GCIC or running anyone or anything on that TG.
Also, has it been confirmed they are running Phase 2 TDMA on the new system? I see a note in RR stating there may be TG's with Phase 2 TDMA.
Thank you
WAYNE1949
macon ga 31216
My Home Patrol 1 was able to scan Macon/Bibb county P-25, Phase I system ,until last week ,my question is it capable are will it ever be capable scanning Phase 11 Harris System .Please excuse me if I am posting this question in the wrong place ,not new to RR but just never post anything much.
Wayne
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Your scanner will work fine on the Phase 2 system however if any of the users start using Phase 2, you won't be able to listen to them.
Make sure your scanner is in ID Search mode since not many talkgroups are known yet. Also make sure you have updated the database.
