Mid-Atlantic MilAir 2024
TerryPavlick
Wallingford PA Villas NJ
I just drove by there today - at least the address that is the mailing address on the website...
by mailing address if you mean the one to the right of the copyright symbol and date - that is the place.
Not very showy since most of our customers are not even in the country and there are none in Delaware.
mdmonitor
1915- Sounds like a couple of DC ANG F-16s are up. Hearing A2A on 238.175. QSY to ZDC Baltimore (134.5) Maybe heading for W107? Also hearing some chat on Warren Grove (283.1)--might be them. Mention of freq 149.125. Chat about using GBU-39Bs. A second flt coming into Warren Grove working ZDC Sea Isle (285.4). NOTE: The GBU-39/B Small Diameter Bomb (SDB) is a 250-pound (110 kg) precision-guided glide bomb that is intended to allow aircraft to carry a greater number of smaller, more accurate bombs.
1920- KC-46s Purdy 45-47 off McGuire heading east. Hearing some chat on 235.1. Might be Purdys.
mdmonitor
1950- Noble 41 flt check in at FL200-220 w/ZDC Cape Charles (293.225)
1953- One of DC ANG flts id'd as Gunny. Second flt mention using GBU-54s
th
Frequency1
NYC area
In addition…139.45 <—(pretty quiet overall, but did get a couple local hits)
mdmonitor
2015- Looks like Decoy 99 (C-17 WVA ANG) getting ready for some AR training in AR 218 (274.45). PA ANG KC-135 # 58-0077 heading that way as well.
2020- CAP 742 (Civil Air Patrol Cessna-172) working Bay Watch for entry into R-4006 " for an exercise". Another Civil Air Patrol Cessna (CAP 753) is also in the area.
2035- Score 04 (C-38 # 94-1570 VX-20) working VX-20 Ops (285.2) w/inbound msg. Had departed from Pease ANGB.
MUTNAV
th
If I understand it right, a GBU-39 and GBU-54 are the same bomb except for a different guidance arrangement. (GPS vs Thermal and Radar target recognition),
Joel
Joel
According to WIKI the GBU-39s are 250LB-ers and the GBU-54 are 500LB-ers
Course the dummy bombs used around here on the ranges are sand or concrete filled.
Make a nice hole in the ground like that Maryland A-10 did some years ago over Kent County MD on way back
from A/C range with a hung up bomb that decided to let go.Prob a small GBU-39 type.
They used to call out their ordinance on way into the A/C range like "Inbound with two GB-32's" but not sure
they do that anymore.
2145 local someone clearing off A/A flight of two on 227.200 and coms on GK 238.900 and W-386 350.050.
Must be humid atmo skip as sound L+C way up here. 227.200 comes back as Langley 71st FS F-22 freq.
apex31
The 305th AMW is keeping busy during their BTF deployment at RAAF Amberley. Pictured below are KC-46s 21-46088, 19-46007, and 20-46074 all operating with the 2nd ARS. Last week (8/20) the KC-46s and B-2s traveled to Diego Garcia for an overnight stop.
Photo cred: SSgt. Whitney Erhart
MUTNAV
It's too bad they don't have a good simulated / subcaliber weapon for the -53...
The military used to use sub-caliber bombs (like 25 pounds) (BDU-33) that simulated a 500 or 2000 ld bomb.
If they could get the fancy electronics to survive to the point of re-use (or made just very low cost), it would be really helpful.
Special aircraft racks can carry a large number of the training rounds (more practice per flight).
Joel
MUTNAV
Joel
Never mind, it's already been thought of for lasers.
Click in the upper left corner for the PDF of the Thesis.
Joel
mdmonitor
for those out there interested in HF here's a nice explanation of the DHS COTHEN network that was posted on another list. This was in response to newcomer's question about the COTHEN network.
Hi Bob. I monitor COTHEN daily and the 2023 frequencies are still in use. I use PCALE to scan the frequencies and decode the ALE. I also run SORCERER because PCALE has some mis-decodes that SORCERER correctly decodes. There is some clear voice traffic after ALE handshakes. Most of it is routine consisting of USCG aircraft requesting COMCOM Chesapeake (LNT/PAC ALE identifiers) assume their radio guard and the terminating guard upon landing. Routine position reports are also sent by the aircraft. There is also clear voice after ALE handshakes between The TCS (Technical Service Center Orlando FL) and various COTHEN users test radios both in the clear and encrypted voice. There is also clear voice after an ale handshake between USCG assets and District Commands. While most traffic on COTHEN is routine, it can also be SAR, law enforcement and hurricane related and very interesting to hear. There is also some clear voice comms from Customs and Border Patrol aircraft with their ground stations through their COTHEN communication expansion nodes. The problem is attempting to follow the communications over-time since they frequently change frequencies to the best available frequency. The voice is also weak at times and hard to understand. As mentioned, you can also sit on a frequency and hear whatever traffic appears on that frequency. The majority of the signals will be ALE sounding which can be annoying at times. Good day light frequencies are 10242, 11494, 13312, 13907, 15867, 18594. Night frequences include 11494, 10242, 8912, 7527, 5909.5 and 5732. I have a day light and darkness set of frequencies I can with PCALE. The bottom line is there is some interesting listening, but it requires lots of patience
freqhopping
N65011 Also flying today and just now taking off again. 127.5
It does have mode-S. Should be coming past me on the way back to the airport.
