MPSCS Sites/Talkgroups 2019
krokus
Southeastern Michigan
Dear Thunderbolt,
If you can help with my question or know who can, I would really appreciate it. I've been searching for a year :giggle: Oh and that would be the headline about the Whistler group. Also I have a TRX-1.
[/QUOTE]
What question?
InOverMyHead
MI
Dear Thunderbolt,
What question?
[/QUOTE]
Hello. I’m looking for clarification on a few things and hoping that someone will help. If you go to the link below (Michigan public safety system), and scroll down the page, you’ll see a category named “Statewide Aeronautical Medical Talkgroups”
https://www.radioreference.com/apps/db/?sid=100
Here are my questions:
1) Is that one whole talk group or is each line part of separate a talk group?
2) I don’t see a talk group ID. How can I locate the specific group IDs?
3) How do I program these in to my Whistler TRX1 by using the scanner - not program software.
Yes. I read the manual and watched videos. I also looked through forums on here and went to alternative websites however, I’m not good with using this scanner or understanding the whole frequency thing.
I haven’t been on here in months because I haven’t used the scanner....at all. Learning this is far worse than writing and defending a dissertation and I’m not joking :) Maybe I shouldn’t be so nosy???
Thanks (again) and I hope you all have a good day.
krokus
Each line is a talkgroup.
Each line has the talkgroup listed in decimal, and hex. For example, Air LZ1 is 1567 in decimal, which is 61f in hex.
They will already be in your scanner, in the database. You would look in EZ Scan for MPSCS, then look for the statewide options, and select those talkgroups from the list, and upload that into your scanner.
RayAir
Macomb County Simulcast:
TG 22866 (clear) Unid Macomb County/Local RIDs
All beginning 950:
6568
6570
6578
6586
6590
6596
6604
Transmissions are from business hours. May be some local gov function.
Lakeville Site
TG 11158 State police RIDs, encrypted
While activity was going on with the encrypted TG, D3North TG (clear) was advising that "ES units" were en route. So it's possible 11158 were the "ES units" but there's no way to know for sure.
This occurred a week ago.
KD8FSJ
Ann Arbor, MI
All beginning 950:
6568
6570
6578
6586
6590
6596
6604
Lakeville Site
I've noted MSP ES units affiliate on TG-11156 before. Maybe a new set of ESU talkgroups?
RayAir
Some of the RIDs matched those used on ES TGs noted in the RR database.
I'm guessing ES is "emergency services" and is like SRT/SWAT?
RayAir
Lapeer County Simulcast
22914 Lapeer county/local RIDs
Encrypted
22926 Lapeer county/local IDs
Encrypted
22928
Noted a couple times from DSD event log/registration/affiliation only
RayAir
Encrypted
Encrypted
22928
Note- Lapeer Central Dispatch RID 2009648 observed on TG 22296.
gbouwkamp
So. East Michigan
TG 12099
Search and rescue drill near Attica (I hope it was a drill, there was no sense of urgency).
RIDS 9443090 through 9443096, identified by single digit number, "one" two" etc. Base IDed as "IC".
Xray
Detroit police chopper - Have been noticing alot of hovering in my vincinity last couple nights [hopefully not over my house], and am seeking any specific freq use of this ship. I assume they use both known LE channels and aviation freqs as well, have been unable to pick up any chatter from the bird so far.
krokus
The Detroit spur site, for MPSCS, with any of the DPD TGs. Depending on their assignment, they could be talking with MSP, too.
BSchaner
Michigan
Hearing TGID 3329 with kent county radio IDs talking about cruisers and checking the radar/status for tornado sirens. Anyone know who this is?
Hello, so I am new to all this digital scanner stuff, I was into it back when the analog scanners worked but since they have switched I haven't done anything relating to scanners and I want to. This might not be the correct place for this question and there might be something out there but I am having issues finding the information I need so any help is greatly appreciated! If someone can tell me or atleast point me in the right direction I would be very appreciative. So I live in Grand Traverse County in Michigan and I am wanting to get a scanner that I can pick up the police, fire, EMS, state police, and even the county road commission because I used to listen to all those back a while ago. So if anyone can help me with this and help me find a scanner that will pick this stuff up that would be awesome! I just dont know where to start and I dont want to buy a scanner and not be able to do what I want to be able to do. If there is something on the cheaper level too that would be awesome to know about, but even the more expensive ones are fine too, I just want to know what will work!
Again thanks so much in advance for your help!
hightime
Menominee County Michigan
From a quick look at your county, you would need a radio that can receive VHF, UHF, P25 Phase 1, (Phase II for future use) , DMR & NXDN. A starting point and I'm not promoting this site it's just a place to compare, you can look at Scanner Master web site, click on scanner tab and then click on Trunking Scanners. From there, it's up to you as what you want. Keep in mind, the antenna's that come with the radios are for general use. Some come with included software. I purchased Proscan and do not regret it. Whistler comes with DMR and NXDN included, Uniden does not (Pay per upgrade). YouTube has a lot of how to for varying scanners. Alot time for research and bring money. Good luck.
krokus
You will need a scanner capable of P25 trunking, for public safety monitoring. With that, I would suggest a newer model, specifically that can receive phase 2 of P25. (Phase 2 will be coming, and this will prevent needing to buy another scanner in a couple years.)
Look in the database, for MPSCS, which is the statewide P25 system, where most of your local public safety comms are. (I do not know if the state police are dispatched via their dispatch station, or by the county.)
Thank you for your reply! This will help me out a lot, definitely more information than I had before now I atleast know where to start, again thank you I appreciate it!
Thank you for the information! It is greatly appreciated! Definitely a huge help for me! Looking forward to getting back into the scanner world!
jbudget3
I have a Copy of all the talk group Names For Clinton county. There are channel names on the paperwork that are not on Radio Reference Site. How would I go about getting the group numbers?
