MRRS System (MTA PD)
coolrich55
connecticut
Question about zone 1 have they moved to more directional based or turned the power down ? Forgive me if this has been brought to light already but I use to receive zone 1 here in SE CT (Waterford/new London area) at full bars but since site 161 has come online I no longer receive zone 1. I updated the CC as stated above and no dice even tried a full spectrum scan on my G4 to find new site info and nothing.
Haven't been down to check in a while but I used to listen to zone 1 from East Lyme with a strong signal.
k2epm
Long Island, NY
I have been out of the loop for a while, so forgive me... the last time I listened to the LIRR PD they were on VHF. The MTA Police -Long Island operated down the block from me at the old Grumman complex. Should I be able to hear this system with my Uniden Beartracker 885, which has Project 25 Phase II scanning capability?
Tank67
New York
No, you'd need a Uniden trunktracking scanner. Considering this is a simulcast system, it'd be best suited for an SDS100 or SDS200 which cost a pretty penny just fyi.
joeya7
Anyone know if an new Zone 3 tower sites have been installed? Specifically Westchester CC?
pro106import
Milford, Ct. perched high above Long Island Sound
Since you mentioned it, I switched my zone over to Westchester, which I rarely use, and wolala, much stronger than they ever were up my way. So my guess is something sure happened. But I dare to speculate what it was.
joeya7
Good to know.
seagravebuff60
Short Bus Reject
Ive been able to pick up Zone 3 here. I thought it was just atmospheric/seasonal conditions. Guess not.
seagravebuff60
Short Bus Reject
I'm still not receiving Harrison PD. I'm able to receive everyone in Westchester 🤔
Harrison PD is currently pretty active in the system. What scanner do you have? From the previous posts it looks like you have an SDS100. Make sure the multi-Dispatch tag is enabled. I would also double-check programming while you're at it.
DEC HEX Mode Alpha TagDescriptionTag
9563255bTHarrison PD/EMSPolice/EMS DispatchMulti-Dispatch
9564255cTHarrison PD TacPolice TacLaw Tac
joeya7
DECHEXModeAlpha TagDescriptionTag
It's just interesting that I receive the other depts just not Harrison. What's multi dispatch tag?
seagravebuff60
Short Bus Reject
Multi Dispatch is the service Tag in the DB, and you can turn the SDS Series scanners on and off. If im not mistaken, the ability to turn them on and off is in the Select Service Types menu options.
Harrison PD is tagged this way in the database as HPD dispatches Harrison EMS on that TG.
Edit: Are you able to receive Scarsdale PD on 9565? That's the only other one that's Tagged Multi-Dispatch in the DB.
joeya7
Thank you for that information I'll give it try. Yes I receive Scarsdale PD.
joeya7
It's now working with multi dispatch enabled. Thanks 👍
Tank67
New York
Went over the Whitestone a few days ago, only saw a BTO tow truck, no BTO/TBTA police cars but quite a few MTA Police cars. It seems that MTA Police units/dispatch are now on TG 9149 patrolling the bridge. Also heard MTAPD units on the Throggs Neck on that TG earlier (they were also using one of the D6/7/11 tacs as well as another TG 9074 for operations on both bridges. Not sure what's going on.
E106MKFD
Westchester, NY
From MTAPD PBA Social Media:
Today is a historic day for the MTAPD. As of March 6, 2025 we are now patrolling the Throgs Neck Bridge and the Whitestone Bridge. The Highway Unit, Emergency Services Unit, K9, Patrol, Command Staff, and the PBA Executive Board were all in attendance to celebrate this significant milestone.
Link:
CqDx
US
After to cutover to F63 system, the radio IDs that registers to the mystery 8099 talkgroup maps exactly within the range of NYSP Troop NYC radio IDs so I think it’s safe to say 8099 is a NYSP talkgroup.
